Best place to buy, Oil pressure gauge to replace clock |
PanelBilly |
Apr 23 2014, 08:28 AM
914 Guru Group: Members Posts: 5,808 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I don't want to do the combo gauge, but want a oil pressure unit. I was thinking of putting it in the center. Any suggestions on who might have one?
boxsterfan |
Apr 23 2014, 09:56 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Get the dual sender also so that you can have the idiot light. At least idiots like me like idiots lights anyways. |
yeahmag |
Apr 23 2014, 10:37 AM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Be forewarned that the Type IV idiot light is set at a much lower PSI than the VDO dual pole sender is, so your oil pressure light may be coming on at idle more than usual.
(IMG:style_emoticons/default/agree.gif) Get the dual sender also so that you can have the idiot light. At least idiots like me like idiots lights anyways. |
worn |
Apr 23 2014, 11:43 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Be forewarned that the Type IV idiot light is set at a much lower PSI than the VDO dual pole sender is, so your oil pressure light may be coming on at idle more than usual. (IMG:style_emoticons/default/agree.gif) Get the dual sender also so that you can have the idiot light. At least idiots like me like idiots lights anyways. Also, while the VDO looks period, I have not found them especially high in quality. I have had one fail outright - stuck at 40 - and the replacement reads about 8 psi low. My solution was to install a T with a direct reading gauge in the engine compartment so I have a basis for comparison. There are other gauges that fit the hole: try ether Summit or Jegs to see the variety. Some of these may be more reliable, but they don't have the same fonts and face that looks right. I am thinking about installing an old VDO gauge that I got on ebay. Have to rebuild the console first. |
Lo-Fi Version | Time is now: 22nd May 2024 - 04:52 AM |
