WCC 05 Virtual Swap Meet!, Make deals here, then swap at the WCC! |
bondo |
Jan 13 2005, 01:20 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Since the WCC has no official swap meet, I thought we could have an unofficial virtual swap meet. List your items to sell/trade and stuff you need here.
(at this point there is no organized time/place to do the swapping during the WCC. You're on your own to make arrangements to swap whatever you're buying/selling/trading) I will post my list of stuff to sell and stuff I need shortly.. I need to think about it (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
bondo |
Jan 18 2005, 06:05 PM
Ok, since I started this I figure I should get around to posting my needs and haves.
I NEED: (I realize some of this is unlikely, but you never know what people have laying around) Euro lenses (all of them) Transmission gasket/seal set Pilot Lites Rear wheel bearings Rear sway bar drop links 228mm KEP clutch/flywheel for late SBC Rear defrost window and/or switch (only if it's cheap, I can live without it, but the rear glass is out right now...) 10 studs for 5 lug hub redrill Drivers side black headlight surround I HAVE: Late style passenger door with all glass and inside door handle (has some bondo on it, and has been cut for a speaker) 3 914 901 cases 1 912 902 case many 901 parts (no H gear) 1.7 or 1.8 engine tin (the two parts with spark plug holes) 1.8/bus heads (rebuilt, says previous owner) Alternator Starter Shifter (late style) Door latch and ignition lock set (key works ignition and one door) Latches need repair late heater blower early heater blower 1.7 distributor (bad vac advance unit) 1 flapper box I can provide pictures if needed. See you at the WCC! |
Lo-Fi Version | Time is now: 28th May 2024 - 04:39 PM |
