WCC 05 Virtual Swap Meet!, Make deals here, then swap at the WCC! |
bondo |
Jan 18 2005, 06:05 PM
Ok, since I started this I figure I should get around to posting my needs and haves.
I NEED: (I realize some of this is unlikely, but you never know what people have laying around) Euro lenses (all of them) Transmission gasket/seal set Pilot Lites Rear wheel bearings Rear sway bar drop links 228mm KEP clutch/flywheel for late SBC Rear defrost window and/or switch (only if it's cheap, I can live without it, but the rear glass is out right now...) 10 studs for 5 lug hub redrill Drivers side black headlight surround I HAVE: Late style passenger door with all glass and inside door handle (has some bondo on it, and has been cut for a speaker) 3 914 901 cases 1 912 902 case many 901 parts (no H gear) 1.7 or 1.8 engine tin (the two parts with spark plug holes) 1.8/bus heads (rebuilt, says previous owner) Alternator Starter Shifter (late style) Door latch and ignition lock set (key works ignition and one door) Latches need repair late heater blower early heater blower 1.7 distributor (bad vac advance unit) 1 flapper box I can provide pictures if needed. See you at the WCC! |
bondo |
Jan 23 2005, 12:17 PM
Addendum: Looks like I also need a decent wiring harness for a 73 (one that hasn't been chewed to bits by varmints)
Lo-Fi Version | Time is now: 7th May 2024 - 07:48 AM |
