I am looking for more opinions on this 2.7 case., Cut off wheel did it's damage. |
wndsnd |
Apr 27 2014, 07:38 AM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Gentle Teeners,
I bought a 2.7 running engine that was in a 911, recently pulled, and brought to Hershey for me. As an old used engine, I was expecting to tear it down and inspect everything so I could evaluate it's usefulness as a rebuild engine to base a conversion around. I got it on the stand and started cleaning and found this 1" cut underneath the cooler mount area. It set me aback..... There is a cut in the case that looks to be made by a cut off disk. Someone got overly aggressive with an exhaust piece or something and ground into the case. It looks to be about 3/16" deep. I have not measured it yet. It does not enter the case, it is not through the case. For all I know the case could be 1" thick here or it could be nearly through. My question is, does this ruin the case? It is not near the head stud area, and I have been told it is in a low pressure oil bypass area. I am not sure how thick the case would be there? Could it cause a stress point that would fail in a freshly built engine and start a crack? This is a magnesium case so I would need to know if it could be welded with success as well. I showed it to the guys at Rich Towles this weekend and we have an opinion, but I would like other engine builders out there to comment before I invest heavily in a conversion around this engine. Hopefully Jake and others that build engines regularly will see this and give me their opinion. Thanks John |
Apr 27 2014, 07:40 AM
It may be in your best interest to clean that case much better, and then take some better pics.....
JStroud |
Apr 27 2014, 07:46 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
I agree, of course I'm on my phone, but I couldn't tell for sure where it is.
What I think is it, isn't clear enough to evaluate. |
wndsnd |
Yes Sir, I am at it .......
wndsnd |
Apr 27 2014, 08:13 AM
wndsnd |
Apr 27 2014, 08:27 AM
wndsnd |
Apr 27 2014, 08:43 AM
Woody |
Apr 27 2014, 10:29 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Woody |
Apr 27 2014, 10:30 AM
Woody |
Apr 27 2014, 10:32 AM
Apr 27 2014, 10:55 AM
Woody |
Apr 27 2014, 11:14 AM
Yeah but they'll want a bare case most likely.
rdomeck |
Apr 27 2014, 12:49 PM
Newbie Group: Members Posts: 31 Joined: 16-April 11 From: Indianapolis, In. Member No.: 12,939 Region Association: Upper MidWest |
Before I starting my fabrication/welding business I was a Porsche mechanic for about 3 years. The shop we worked at did all major work on air cooled Porsche's.... Between the two of us we probably built over a hundred engines in that 3 year time period. I would have no problem leaving that case as is and rebuilding it. The case in that area is much thicker than the cut is deep.
Continue on with your rebuild and don't worry about it! |
iamchappy |
Apr 27 2014, 02:13 PM
I would put a little JB weld on it for appearance sake and forget about it.
Woody |
Apr 27 2014, 02:16 PM
If I can remember tomorrow, I'll bring home one of my extended reach calipers and try to take a measurement for you on the wall thickness of that galley.
wndsnd |
Apr 27 2014, 02:35 PM
Thanks guys,
I have been cleaning and dissassembling all day. This engine looks good to me. There are no signs of stud pull, it was the mild 2.7 and it did not start in CA so it never had the cats. I am hoping the consensus is to forget about it. It looks to be original and the case has not been split. The cam chain covers have been opened though, as there is some silicone gooping out, but the case looks intact and the heads and cylinders look like they have never been touched as well. We will see where this goes John |
wndsnd |
Apr 27 2014, 04:04 PM
wndsnd |
Apr 27 2014, 04:05 PM
Woody |
Apr 27 2014, 04:15 PM
Oooh that's ugly.
wndsnd |
Apr 27 2014, 04:31 PM
I have some pre buy leak down numbers.
1 8% 6 15% 2 20% 4 8% 3 14% 5 10% I will work on the tensioners and re-do the leak down and see what I get. Thanks Woody. John |
Lo-Fi Version | Time is now: 16th May 2024 - 06:34 AM |
