FS: Mostly stock parts from 1.7 part out., Assorted stuff inside. |
BMXerror |
Apr 27 2014, 04:45 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Hey all. I've sold most of the fancy race pieces off of my former autocross car, but I've still got a small stockpile of stock pieces that I would like to send to a good home. Condition varies. All prices are plus shipping. Not sure what some of this stuff is worth, so feel free to make reasonable offers. Please PM me if you see anything you like as I'm not very good at getting back and checking these threads. I can also provide pictures upon request.
-19mm master cylinder. Rebuilt 5 years ago. Less than 10k miles and maybe 10 autocross events on it. Works great. $100 -Stock early front calipers. Rebuilt at the same time as the master cylinder. Work perfectly. Could be dressed up with some caliper paint. -1.7 long block. Heads have some major cracks. Bottom end is solid. FAT 440mp camshaft, strait cut cam gears, hi flow oil pump, AA pistons/cylinders. -1.7 alternator. Came off of running car. Haven't checked output, but seemed to be working fine. Cooling boot is torn. Make offer -Stock half shafts with 4 bolt CVs. CVs are tight and quiet. -Stock hazard light switch. Condition is 8/10. $35 -Front upper strut mounts. $20 -Individual D Jetronic injectors. 1 yellow. 1 black. Not flow tested, but functioning properly. Make offer. -Kennedy stage 1 pressure plate and stock clutch disc with 75% material left. $150 The rest of this stuff may be junk or may be somebody's treasure. If I don't find a home for it soon it will go to the recycler or the landfill. On all the stuff without a price, just make an offer and cover shipping charges. -Late seats all black. Some tears in upholstery. Appearance is 5/10. Still plenty useable/comfortable. Local sale preferred. -2 Side shift transmissions. One needs a rebuild to make it usable. $50 as a core. The other was a driver, but was starting to get some grind out of 1st and 2nd. $100 -Bosch 009 distributor with vacuum can. -D-Jet ECU and wiring loom. free to whoever rebuilds them -Side window glass. Glass is in good shape but no longer bonded to metal guide pieces. Not sure if this is fixable, but I still to have the metal pieces. -Plastic headlight motor mechanism covers. Pair. -Washer bottle. Some blue overspray which may be removable. -Heater lever. Appearance 7/10 Hope somebody can get some use out of some of this stuff. Mark D |
MikeInMunich |
Apr 27 2014, 05:42 PM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Interested in heating plumbing and blower. Sending PM.
914bub |
Apr 27 2014, 05:51 PM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
PM sent on side shift linkage.
Apr 27 2014, 06:25 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would like the djet ecu, wire harness and mps for my 1.7 car. I will PM you with my address and you can reply with your PayPal so I can cover shipping. Any other 1.7 parts you care to throw in are appreciated. Thanks, mark
brant |
Apr 27 2014, 10:43 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Mps pm
BMXerror |
May 5 2014, 09:16 PM
Larmo63 |
May 5 2014, 10:51 PM
I would take the headlight plastic motor mechanism covers if they aren't cracked.....
BMXerror |
May 9 2014, 11:43 PM
BMXerror |
May 14 2014, 09:40 PM
(IMG:style_emoticons/default/icon_bump.gif) Some of this stuff is gonna start making it's way to the garbage little by little.
Mark D. |
BMXerror |
May 26 2014, 04:24 PM
BMXerror |
May 29 2014, 09:06 PM
BMXerror |
Jun 13 2014, 07:36 PM
(IMG:style_emoticons/default/icon_bump.gif) Oil cooler sold.
Mark D. |
BMXerror |
Jul 13 2014, 03:02 PM
Long time, no (IMG:style_emoticons/default/icon_bump.gif) .
Mark D. |
BMXerror |
Jan 24 2015, 12:10 PM
(IMG:style_emoticons/default/icon_bump.gif) Help me fund my latest autocross project. (IMG:style_emoticons/default/driving.gif)
Mark D. |
Lo-Fi Version | Time is now: 21st May 2024 - 02:05 AM |
