rear brake clearance, access hole on trailing arm |
cpavlenko |
Apr 30 2014, 04:18 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
anybody know what size the bolt is for rear brake clearance in the trailing arm. (IMG:style_emoticons/default/wacko.gif)
yeahmag |
Apr 30 2014, 04:32 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
M6 allen if I remember right... I know what color it is in my color coded caddy!
914_teener |
May 1 2014, 07:25 AM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
bdstone914 |
May 1 2014, 08:31 AM
It is not a 6mm. I think it is a 5mm. The plug and inner adjusting screws take the same size allen.
mskala |
May 1 2014, 08:48 AM
If you still have the original plug, it is either 4 or 5 mm. I wouldn't bet the house on it, but I'm going with 4mm. They tend to strip and in the old days I would put a big
slot in the head for a screwdriver. The adjuster inside is 4mm. |
stugray |
May 1 2014, 09:03 AM
I just did this the other day.
And after looking at my brakes parts stash, there were three different types of caps before getting to the adjuster. On the car was a cap with a 10mm bolt head cap with 4mm adjuster underneath. One set of spare rears had a socket hex cap (maybe 6mm), while the third had a standard screwdriver slotted cap. |
hndyhrr |
May 1 2014, 09:27 AM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
I just did this on my 70, 5 mm into the cap be careful not to strip it or else it's the chisel. adjusting screw inside is 5 mm also.
cpavlenko |
May 1 2014, 10:00 AM
Yep, it's a 4 mm hex key to adjust inner clearance.
Lo-Fi Version | Time is now: 16th May 2024 - 05:23 PM |
