cpavlenko
Apr 30 2014, 04:18 PM
anybody know what size the bolt is for rear brake clearance in the trailing arm.
yeahmag
Apr 30 2014, 04:32 PM
M6 allen if I remember right... I know what color it is in my color coded caddy!
914_teener
May 1 2014, 07:25 AM
Or a Craftsman chisel if you're not careful.
bdstone914
May 1 2014, 08:31 AM
It is not a 6mm. I think it is a 5mm. The plug and inner adjusting screws take the same size allen.
mskala
May 1 2014, 08:48 AM
If you still have the original plug, it is either 4 or 5 mm. I wouldn't bet the house on it, but I'm going with 4mm. They tend to strip and in the old days I would put a big
slot in the head for a screwdriver.
The adjuster inside is 4mm.
stugray
May 1 2014, 09:03 AM
I just did this the other day.
And after looking at my brakes parts stash, there were three different types of caps before getting to the adjuster.
On the car was a cap with a 10mm bolt head cap with 4mm adjuster underneath.
One set of spare rears had a socket hex cap (maybe 6mm), while the third had a standard screwdriver slotted cap.
hndyhrr
May 1 2014, 09:27 AM
I just did this on my 70, 5 mm into the cap be careful not to strip it or else it's the chisel. adjusting screw inside is 5 mm also.
cpavlenko
May 1 2014, 10:00 AM
Yep, it's a 4 mm hex key to adjust inner clearance.
