| Kansas 914 |
May 9 2014, 12:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,008 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
have you looked in from the front of that tube behind the speaker? That is nasty... I think the varmint is living in the fresh air box and making the "long" trip down the tubes to the end and using that as the bathroom... So you have just uncovered the toilet not the bedroom. (IMG:style_emoticons/default/hide.gif) |
| Moneypit |
May 9 2014, 12:09 PM
Member ![]() ![]() Group: Members Posts: 195 Joined: 4-January 06 From: Georgetown, TX Member No.: 5,360 Region Association: Southwest Region |
Peanut butter sandwich, anyone? (IMG:style_emoticons/default/chowtime.gif)
| sixnotfour |
May 9 2014, 01:22 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,351 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
DAPO (IMG:style_emoticons/default/barf.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/icon8.gif) (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/stromberg.gif) (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/w00t.gif)
| JRust |
May 9 2014, 01:31 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
have you looked in from the front of that tube behind the speaker? That is nasty... I think the varmint is living in the fresh air box and making the "long" trip down the tubes to the end and using that as the bathroom... So you have just uncovered the toilet not the bedroom. (IMG:style_emoticons/default/hide.gif) I did actually. I used a small camera on an adjustable end to see in the tube.I couldn't see it from that end |
| r_towle |
May 9 2014, 04:51 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Are you using the heater tubes?
If not, I might suggest you use a drill bit, on an extension, possibly a custom rig that would totally shred that paper tube and shred it. Then vacuum it out of there... |
| Mike Bellis |
May 10 2014, 11:39 AM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
You could get a water jet fitting on a garden hose that aims backwards. Stuff it in the hole and turn on the water. Then slowly drag the hose out. It will clean it out...
| tomeric914 |
May 10 2014, 08:03 PM
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,324 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States
After that I'll get some por 15 or something along those lines to make sure I kill any rust that may have started. POR15 is a rust encapsulator that needs proper surface preparation to adhere well. Probably shouldn't use that there. Eastwood makes an undercoating gun with various spray heads that works well. Undercoating from the inside may help but you may be further ahead to carefully cut a window in the long and pull everything out. |
| Katmanken |
May 10 2014, 09:26 PM
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
And now we know what happened to Jimmy Hoffa....
| JRust |
May 12 2014, 10:20 AM
You could get a water jet fitting on a garden hose that aims backwards. Stuff it in the hole and turn on the water. Then slowly drag the hose out. It will clean it out... So saturday I did this. Put a high pressure nossle on my hose. Fed it down the long from behind the passenger side speaker. Turned it on & let it run a bit. The slowly pulled it back out. It is much better. I no longer smell it in the car. I also fed some oil stuff my wife makes called Purify. It kills bacteria & has a nice smell to it. I can still smell a bit outside but could be from gunk that got sprayed back on the motor & engine bay. Shouldn't be to much there but I'll jack it up & spray the area out good. I drove it to work today & just being out in the open air. I think I have it basically gone. So my trip to WCR should be a pleasant stench free ride (IMG:style_emoticons/default/piratenanner.gif) |
| Kansas 914 |
May 12 2014, 10:27 AM
So saturday I did this. Put a high pressure nossle on my hose. Fed it down the long from behind the passenger side speaker. Turned it on & let it run a bit. The slowly pulled it back out. It is much better. I no longer smell it in the car. I also fed some oil stuff my wife makes called Purify. It kills bacteria & has a nice smell to it. I can still smell a bit outside but could be from gunk that got sprayed back on the motor & engine bay. Shouldn't be to much there but I'll jack it up & spray the area out good. I drove it to work today & just being out in the open air. I think I have it basically gone. So my trip to WCR should be a pleasant stench free ride (IMG:style_emoticons/default/piratenanner.gif) That is great news - enjoy the ride to the event! |
Lo-Fi Version | Time is now: 2nd September 2026 - 06:39 PM |
