3.6 conversion questions |
mrbubblehead |
May 3 2014, 08:03 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i finally got the engine for my dream car build. it is a 1997 3.6 minus the induction system and brain. i am still in the air about the induction. i am leaning towards the clewette itb system.
my first question for you guys who have done the conversion is, did you have to go to a single pulley system? or was there enuff room to use the two pulley system? clewette sells a two groove pulley with a trigger wheel that would be great for me but i seem to remember reading there is not enuff room for the two pulley set up. what are you guys using? |
JStroud |
May 3 2014, 09:26 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
I had to take the double pulley off my 2.7, and install a single pulley for my mount to fit, I'm using a 914-6 replica mount made by Original Customs.
Jeff |
hblyle |
May 4 2014, 01:02 AM
Member Group: Members Posts: 64 Joined: 23-May 11 From: Huntington Beach Member No.: 13,110 Region Association: Southern California |
Saw this on Craigslist
http://sandiego.craigslist.org/nsd/pts/4451509800.html My 3.6 is still in the donor car. |
pcar916 |
May 4 2014, 11:11 AM
I converted to the single pulley because of the clearance issue. The Porsche replica fan/alternator hub I used was from Patrick Motorsports and although slightly big on the ID* easily, it was painless. I sent him my 993 pulley and he mated the hub with a single-row 930 pulley. The only drawback is that it underdrives the alternator.
That means that, most of the time, idle rpm designated by the DME won't start the alternator flowing juice until the throttle is blipped once. ... not generally a big problem unless you have electronics sensitive to current fluxuations. * .013in. bore on the pulley hub, shimmed with .005in. wrapped around the shaft. That left only .003in. When I asked Patrick about it he told me that it was an exact replica of the factory part. Good luck |
May 4 2014, 11:22 AM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
0396 |
May 4 2014, 11:49 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
The factory has a RS single setup. Then there's aftermarket too
mrbubblehead |
May 4 2014, 12:19 PM
yes, im aware of the rs set up. im researching it now. i need to find an rs set up with a trigger wheel.
Mike Bellis |
May 4 2014, 01:50 PM
Why not go with a factory Motronic system? All the engineering is done and the Motronic can be tuned for performance. That CL ad has everything you need at a good price.
I used the Motronic 7.5 system on my Audi conversion and the car starts and runs like a new car. The fuel and timing maps were tweaked for my big turbo and the ECU controls the boost up to a set max of 20psi. It runs way better than any aftermarket EFI system I ever had or drove. |
pcar916 |
May 4 2014, 02:31 PM
A turbo chip can be tweaked quite a bit with good results. But, other than raising the redline, does anyone have quantified results on horsepower and torque gains possible with normally-aspirated engines? It certainly isn't as much.
mrbubblehead |
May 4 2014, 03:39 PM
Why not go with a factory Motronic system? All the engineering is done and the Motronic can be tuned for performance. That CL ad has everything you need at a good price. I used the Motronic 7.5 system on my Audi conversion and the car starts and runs like a new car. The fuel and timing maps were tweaked for my big turbo and the ECU controls the boost up to a set max of 20psi. It runs way better than any aftermarket EFI system I ever had or drove. honestly mike, i am a tinkerer. and with this car i have the time and dough to go with itb's. |
0396 |
May 4 2014, 05:51 PM
Itb...you might want to look at Rennsport System in Portland. They have a system that will increase that 3.6 HP north of 345 -(IMG:style_emoticons/default/smile.gif)
0396 |
mrbubblehead |
May 4 2014, 07:02 PM
Itb...you might want to look at Rennsport System in Portland. They have a system that will increase that 3.6 HP north of 345 -(IMG:style_emoticons/default/smile.gif) i have been on their website looking at their pulley systems, but the links to their itb kits are broken.... (IMG:style_emoticons/default/hissyfit.gif) |
mrbubblehead |
May 4 2014, 07:10 PM
Itb...you might want to look at Rennsport System in Portland. They have a system that will increase that 3.6 HP north of 345 -(IMG:style_emoticons/default/smile.gif) i have been on their website looking at their pulley systems, but the links to their itb kits are broken.... (IMG:style_emoticons/default/hissyfit.gif) shit, i mean rothsport website.... i will have to look into rennsport. thank you for the tip. |
ClayPerrine |
May 5 2014, 05:07 AM
Here is what you need for an intake....
SUPERCHARGER!! (IMG:http://www.914world.com/bbs2/uploads_offsite/splitsec.com-1143-1399288059.1.jpg) |
Justinp71 |
May 6 2014, 12:01 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
PMO Carbs!!! I guess they are starting to be a thing of the past... but I still love them. (IMG:style_emoticons/default/wub.gif) |
May 6 2014, 11:12 AM
PMO Carbs!!! I would have never done this swap with a carbed motor. Nothing like a car starting up each and every time with the first turn of the key, no matter where you are and at what altitude. (IMG:style_emoticons/default/driving.gif) |
JmuRiz |
May 6 2014, 11:31 AM
914 Guru Group: Members Posts: 5,426 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
If it has stock DME FI, keep it...carbs on a 3.2 or 3.6 would be insane.
Heck, I've given thought to keeping CIS on my 2.7, just for ease of start. |
ClayPerrine |
May 6 2014, 01:21 PM
PMO Carbs!!! I would have never done this swap with a carbed motor. Nothing like a car starting up each and every time with the first turn of the key, no matter where you are and at what altitude. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/agree.gif) Why go with an overgrown perfume atomizer when you can have a modern, computer controlled system that starts and runs well everytime? |
mrbubblehead |
May 6 2014, 01:33 PM
PMO Carbs!!! I would have never done this swap with a carbed motor. Nothing like a car starting up each and every time with the first turn of the key, no matter where you are and at what altitude. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/agree.gif) Why go with an overgrown perfume atomizer when you can have a modern, computer controlled system that starts and runs well everytime? carbs were never really on my radar, that is why im almost certain i am going with itb's. |
Lo-Fi Version | Time is now: 16th May 2024 - 12:12 AM |
