Removing Copper Exhaust Gaskets, Any Magic Ideas |
74914LE |
May 4 2014, 03:11 PM
Member Group: Members Posts: 136 Joined: 6-April 04 From: Fort Worth, TX Member No.: 1,895 |
Decided to switch to Stainless Steel Heat Exchangers, and am in the process of
removing the old copper exhaust gaskets. A couple of them are not interested in coming out. Any magic ideas to try to get these things out? Any special tool to buy to get the job done? Thanks in advance! |
May 4 2014, 03:29 PM
use a small nail set or punch.
Hit the gasket on the middle of the long sides....if done properly, it wil bend the gasket slightly on the end. Then hook it with a hook or screw driver. Rich |
jmalone |
May 4 2014, 03:31 PM
Member Group: Members Posts: 119 Joined: 3-July 09 From: reno,NV Member No.: 10,529 Region Association: Northern California |
Try a small pick. Usually available as part of a set at Harbor Freight or FLAPs.
TheCabinetmaker |
May 4 2014, 05:14 PM
I made a hook from an old screwdriver. I've also had to use a straight screwdriver and a hammer. Hammer the screwdriver(gently) between the copper gasket and head,.Then turn the screwdriver.then you can get ahold of the copper with some pliers.
wndsnd |
May 4 2014, 06:26 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I agree with Rich. I use a small chisel and whack it in the middle. The soft copper gives and usually pops up enough to get a pick or screwdriver under it.
John |
914_teener |
May 5 2014, 07:55 AM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Try a small pick. Usually available as part of a set at Harbor Freight or FLAPs. (IMG:style_emoticons/default/agree.gif)+1 This is the tool to use...HF makes a set of them. |
VaccaRabite |
May 5 2014, 09:24 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I usually just use a thin, flat blade screwdriver. It does not take much to get them started, and once they move even a little bit they come out pretty easy.
A dental pick from HF would work too. Zach |
Gearhead1432 |
May 6 2014, 12:52 AM
Member Group: Members Posts: 129 Joined: 21-December 05 From: Altus, OK Member No.: 5,304 Region Association: None |
Just don't do what I did and cut straight through the gasket with a small chisel subsequently gouging the head.
HAM Inc |
May 6 2014, 09:22 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Just don't do what I did and cut straight through the gasket with a small chisel subsequently gouging the head. Over the years I've seen countless heads damaged in this way. If the copper gasket is not grooved or otherwise damaged leave it in. If you do want to take a whack at it with a chisel hit the outboard side, not the long side that's closest to the center of the head. The flange there is not backed up by much material and there is a high chance it will chip the head. Do that and an ex leak is guaranteed til you remove the head and weld it up. |
reharvey |
May 6 2014, 09:51 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
Just don't do what I did and cut straight through the gasket with a small chisel subsequently gouging the head. Over the years I've seen countless heads damaged in this way. If the copper gasket is not grooved or otherwise damaged leave it in. If you do want to take a whack at it with a chisel hit the outboard side, not the long side that's closest to the center of the head. The flange there is not backed up by much material and there is a high chance it will chip the head. Do that and an ex leak is guaranteed til you remove the head and weld it up. (IMG:style_emoticons/default/agree.gif) I have a dozen heads sitting in my garage and half of them have the type of exhaust port damage mentioned here. Be careful when removing that copper ring! |
914Mels |
May 6 2014, 02:11 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
There is a tool called a ladies foot, it's a small pry bar with a quarter moon end on it. The smaller versions fit right into the exaust port and you can easily pry the ring out.
Lo-Fi Version | Time is now: 16th May 2024 - 05:48 AM |
