Why can't I reinstall my shifter bearing bracket, I have installed this in my trans before |
Harpo |
May 4 2014, 05:45 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Harpo |
May 4 2014, 05:46 PM
Cap'n Krusty |
May 4 2014, 06:38 PM
Is the trans in neutral? Gotta be for the console to go in.
The Cap'n |
May 5 2014, 08:16 AM
Which part are you having trouble with? The new add-on with the second flange? That doesn't look like it is lined up correctly, but I don't have any experience with those so it could be normal.
If you're talking about getting that selector rake in, there are a few considerations. - Like the Cap'n says, the trans has to be in neutral. - It may start to go in easier with the shift rake turned around backward, but you can't get it turned around the right way after you start it--so don't do that. - You will need to do some rocking back and forth of the whole console to get the bits of the rake to clear the various bits inside the trans and the edge of the hole through the case. --DD |
Harpo |
May 5 2014, 03:44 PM
At the risk of asking a dumb question do I simply line up the slots?
Thanks DAvid |
Cupomeat |
May 5 2014, 03:53 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Yes, it has to be in neutral, and you have to rock it back and forth to get the teeth of the selector properly in the hole.
Otherwise, it should go right in. Good luck |
May 5 2014, 07:36 PM
Look inside, you can see the teeth.
Lo-Fi Version | Time is now: 16th May 2024 - 05:37 AM |
