Harpo
May 4 2014, 05:45 PM
I was not able to install my shifter brg bracket. I have installed this before but today had no luck. Could my shift rods be out of alignment
Harpo
May 4 2014, 05:46 PM
Cap'n Krusty
May 4 2014, 06:38 PM
Is the trans in neutral? Gotta be for the console to go in.
The Cap'n
Dave_Darling
May 5 2014, 08:16 AM
Which part are you having trouble with? The new add-on with the second flange? That doesn't look like it is lined up correctly, but I don't have any experience with those so it could be normal.
If you're talking about getting that selector rake in, there are a few considerations.
- Like the Cap'n says, the trans has to be in neutral.
- It may start to go in easier with the shift rake turned around backward, but you can't get it turned around the right way after you start it--so don't do that.
- You will need to do some rocking back and forth of the whole console to get the bits of the rake to clear the various bits inside the trans and the edge of the hole through the case.
--DD
Harpo
May 5 2014, 03:44 PM
At the risk of asking a dumb question do I simply line up the slots?
Thanks
DAvid
Cupomeat
May 5 2014, 03:53 PM
Yes, it has to be in neutral, and you have to rock it back and forth to get the teeth of the selector properly in the hole.
Otherwise, it should go right in.
Good luck
r_towle
May 5 2014, 07:36 PM
Look inside, you can see the teeth.
