lug bolt length for Riviera Wheels?, have 25mm thread, should it be 38mm |
smarens |
May 6 2014, 06:20 PM
Member Group: Members Posts: 69 Joined: 15-March 14 From: Michigan Member No.: 17,121 Region Association: None |
looks like I have 5-6 threads of engagement, can't believe that is correct, just posted add for 38mm for my Mahle's that I just refinished and put new tires on
-still want to drive with my Riviera's on but wondering is it safe? |
smarens |
May 7 2014, 01:30 PM
39 views and no expert chimed in yet, I know most of you guys have a solid and experienced opinion, please share
thanks |
Cap'n Krusty |
May 7 2014, 01:57 PM
The book only lists two part numbers. In all the years I've been working on 914s, I've never seen or used anything other than the lugbolts that were stock for the steel wheels in conjunction with Riviera wheels. The longer bolts are used with Mahle, Pedrini, and Fuchs wheels.
If you're using spacers of any kind, the short bolts will not work. The Cap'n |
stugray |
May 7 2014, 02:04 PM
These I got from Brant for 2.0L Fuchs:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1399493091.1.jpg) Stu |
smarens |
May 7 2014, 02:12 PM
thanks guys, I know that I need the 38mm for my Mahles, was spooked by how short the ones are on the Riv's now, no wheel spacers, just little spooky short to me
reharvey |
May 7 2014, 02:41 PM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
The book only lists two part numbers. In all the years I've been working on 914s, I've never seen or used anything other than the lugbolts that were stock for the steel wheels in conjunction with Riviera wheels. The longer bolts are used with Mahle, Pedrini, and Fuchs wheels. If you're using spacers of any kind, the short bolts will not work. The Cap'n (IMG:style_emoticons/default/agree.gif) I've had Riviera wheels on several of my cars and always used the OEM lugbolts from the 914 steel wheels without any problems. |
smarens |
May 7 2014, 05:39 PM
I was worried thanks, I knew you guys would know if I was alright until I find 38mm for my Mahles
Lo-Fi Version | Time is now: 16th May 2024 - 03:27 AM |
