> 2056 still working out the bugs
jmargush
post May 13 2014, 03:04 PM
I am sorting out my recently built 2056 specs below:
2.0 Heads were done by Len Hoffman
CR 8.56:1
Full Raby valve train kit
Stock L-jet throttle body, air cleaner, and intake runners
stock 2.0 heat exchangers
pertronix ignition
It has a miss under hard acceleration.
All the vacuum lines and oil cap gaskets are new and I can't seem to find a leak any where.
So I decided to recheck the timing.
Pulled vac lines off the vacuum diaphragm and plugged, set idle to 800 rpm
timing was a little more advanced than it should be but not dramatically, but I did reset to factory setting.
Drove it and it is even worse than before.
Would the new engine combo warrant a different timing?
Fuel filter is new but my next step is to check fuel pressures and injectors.
Anything else I should be looking for?
Mblizzard
post May 13 2014, 03:20 PM
I only suggest this because I have done it (IMG:style_emoticons/default/headbang.gif)
Not saying anyone else would.... But be sure you use the correct timing marks on the impeller.
I am running a 2056 with D-jet and have been struggling with timing for a while. But the stock setting when dome correctly seems to be acceptable. There is some good info in another thread I started. Most of it was added by others more knowledgeable than me and who know which timing marks to use.
I am adding a AF gauge to tune it a little better and adjust the MPS.
McMark
post May 13 2014, 03:29 PM
914 Freak!
You should have a Wideband O2 sensor in there before doing much driving.
914_teener
post May 13 2014, 03:59 PM
He has L-jet not D-jet.
Cupomeat
post May 13 2014, 04:04 PM
missing my NY 914 in VA
Can I assume that this L-Jet system was working fine before you did all the engine work?
A couple of things... If it had a bad vacuum leak it would not idle at 800rpm, so that leads me elsewhere.
I'd keep looking into ignition as L-jet is pretty solid once you verify the vacuum leaks are gone. Do you have anything to swap out the pertronix to test?
And I agree about the wideband 02 given the amount of money you spent on that motor, it is cheap insurance and a great tuning aid. Just avoid going lean at Full Throttle.
Good luck and post the progress.
jmargush
post May 13 2014, 04:24 PM
For the wide band O2 do you weld that into the heat exchanger or how does it get set up?
I assume you use that with an AF gauge correct?
the L-jet was working before the idle does some funny things.
On start up it idles well below 800, probable 300-500
once warmed up and you come to a stop the idle won't drop till you start to let the clutch out and hold the brake to have the load pull it down then it idles around 800.
Don'tr know if this is a separate issue or linked?
I have other non pertronix distributors I could try, but this worked great before the rebuild
Mblizzard
post May 13 2014, 04:52 PM
QUOTE(McMark @ May 13 2014, 01:29 PM) *
(IMG:style_emoticons/default/agree.gif) on the wideband! I played around for a long time and made a little progress but it was just trial and error. Mostly error!
Porschef
post May 13 2014, 05:00 PM
How you doin'
How does it perform on a cold start?
Mblizzard
post May 13 2014, 05:02 PM
Also check your injector seals. I had a pretty good leak on one of mine. Installation error! Wish I could blame it on McMark but everything he did to my engine seems to work. Just wish he was on the east coast!
Dave_Darling
post May 13 2014, 06:03 PM
914 Idiot
QUOTE(jmargush @ May 13 2014, 03:24 PM) *
Sounds like it might be something (the advance mechanism) sticking in the distributor.
--DD
jmargush
post May 13 2014, 06:45 PM
Cold start performance is pretty much the same I just don't notice the miss as much since I wait to get on it till it warms up.
injector seals are all new but I'll check the installation just to make sure.
jmargush
post May 14 2014, 02:53 PM
QUOTE(Mblizzard @ May 13 2014, 03:52 PM) *
How did you install you o2 sensor?
Did you buy some sort of kit that included a weld in bung and gauge to read what the o2 sensor is reading?
Mblizzard
post May 14 2014, 03:24 PM
QUOTE(jmargush @ May 14 2014, 12:53 PM) *
Yep on the weld in. I got a AEM 30-4100. May not keep it in all the time as I hope to get things set and the remove the gauge and sensor. Will replace the exhaust O2 sensor with a plug but leave the wiring in place so I can quickly replace the sensor if I need to.
Java2570
post May 14 2014, 03:28 PM
The AEM air fuel gauge I bought included the O2 sensor and the bung to weld onto the exhaust.
I started out using the no weld clamp (you have to drill a hole in the exhaust) and it works ok but
in retrospect, I'd get it welded if I did it again. That was on a Bursch muffler....if you're using heat
exchangers, it's best to install the bung on the muffler pipe after the collector merges. I'm not sure
there's a way to do it very well using a stock muffler....you could only use one side of the exhaust.
What's your setup, exhaust-wise?
Mblizzard
post May 14 2014, 05:29 PM
I have a Bursch exhaust. There is a good location on the passagners that allows the O2 sensor to be angled to avoid water collection on the sensor. If my back holds out I will run the wires tonight and have it going tomorrow. I lift weights 3 times a week and never had a back problem. Sneezed hard this morning and tweaked my back (IMG:style_emoticons/default/WTF.gif)
Java2570
post May 14 2014, 05:42 PM
I hear ya on the back crap, I didn't start having issues until last year. Of course, I get the adrenaline all
up working on the car and don't notice much until after the fact.....it's usually the next day that kills me.
I get to replace the clutch cable this weekend!
jmargush
post May 14 2014, 06:52 PM
Stock heat exchangers with a Thunderbird exhaust which is similar to Bursch as far as how the plumbing runs.
Any pictures of your O2 set ups?
I made a little progress this evening
Vacuum diaphragm on dizzy was bad on the retard side thus the not coming down to idle.
Didn't get a chance to run it on the road as it was raining but I did shave the grommet for the wires running form the pertronix as they were mighty close to the plate that rotates for advance, just incase that was making the plate hang up on advance.
Hopefully I will get a chance to try it tomorrow.
Mblizzard
post May 14 2014, 07:04 PM
QUOTE(jmargush @ May 14 2014, 04:52 PM) *
Have not welded in the bung yet. Have just done the mock up. Will be tomorrow before I can get to it but I will post some pictures. The AEM AF gauge seems pretty well made. Looks like the spent the most on the O2 sensor but the wires don't look like they were done cheap and the connectors seem to be of good quality. The actual gauge is a little cheap feeling though.
jmargush
post May 15 2014, 01:57 PM
Well the new diaphragm on the distributor didn't fix the miss under hard acceleration.
So I tried another distributor with points no success, so I advanced the timing a little just to see and no difference.
So do I still keep looking at ignition or is there a possibility is is just to lean that there isn't enough fuel under hard accel.?
I know this is what the AF gauge and O2 are for but that isn't going to happen in the next two days, and I really wan to run it at the autox this weekend.
Java2570
post May 15 2014, 02:36 PM
Did you ever get a check on what your fuel pressure is running at? You mentioned it in the first post
that it was on the list but if you haven't, I'd check that first. I don't have any knowledge of L Jet as my car still has D Jet but I'd think that the only real way to proceed would be the AFR gauge.
On D Jet, one can disconnect the Temp Sensor 1 on the plenum to richen it slightly but I don't think
L Jet has that sensor. After looking at the manual for L Jet on Jeff Bowlsby's site....it looks like that sensor (Temp 1) is built into the air flow meter? This has some great L jet info: http://www.google.com/url?q=https://bowlsb...RPW3jnJpjKbZiwQ
- Lo-Fi Version Time is now: 11th March 2026 - 11:39 PM
