> Stuck 6 cyl head, No, its not stuck there....
mr914
post May 15 2014, 11:12 AM
Post #21
914 Hillbilly
Pulling apart that Aluminum case 2.0 motor in anticipating to sell it and cant seem to get one of the heads off.
Motor has been sitting for 20 plus years and rotates freely.
4 heads came off with a little more than a ketchup bottle thump.
1 head came off with the cylinder attached
The other one, wont seem to budge. Made sure all washers were removed. been soaking with PB Blaster for a couple of days
BTW: motor had been sitting for several years and a mouse had made a nest on top of that particular cylinder.
Hence - Mouse motor...
Any suggestions? (IMG:style_emoticons/default/confused24.gif)
mr914   Stuck 6 cyl head   May 15 2014, 11:12 AM
stugray   I would suggest filling up the cyl with a little o...   May 15 2014, 11:21 AM
Justinp71   More power! :smash: When I did mine I remov...   May 15 2014, 11:21 AM
mr914   Stugray = you may be on the right track. With n...   May 15 2014, 11:43 AM
mr914   5 of 6 cylinders heads off 3 cylinders off   May 15 2014, 11:44 AM
Mike Bellis   Put a spark plug back in it at BDC and rotate the ...   May 15 2014, 12:17 PM
mr914   If I was going to do that, shouldn't I remove ...   May 15 2014, 12:21 PM
Mike Bellis   If I was going to do that, shouldn't I remove...   May 15 2014, 12:51 PM
Jon B   Check to make sure all cylinder head nuts are remo...   May 15 2014, 01:15 PM
KELTY360   Wouldn't the rope trick work? Get piston at BD...   May 15 2014, 01:44 PM
Scott S   Wouldn't the rope trick work? Get piston at B...   May 15 2014, 02:46 PM
toolguy   do not pry against the cylinder fins, they will b...   May 15 2014, 01:56 PM
Jon B   ...if you hit sideways it can bend the rod. Bend a...   May 15 2014, 02:23 PM
Nine_14   If none of the above given suggestions helps, brin...   May 15 2014, 02:26 PM
mr914   If none of the above given suggestions helps, bri...   May 15 2014, 02:37 PM
Nine_14   If none of the above given suggestions helps, br...   May 15 2014, 02:48 PM
mr914   Confirmed last night that all of the nuts and wash...   May 15 2014, 02:42 PM
injunmort   gently heat the seam with a torch or heat gun, the...   May 15 2014, 04:08 PM
get off my lawn   M-80 in the spark plug hole. hey it works on cats ...   May 15 2014, 05:04 PM
76-914   Anyone that would do that to any animal is a sick ...   May 15 2014, 07:04 PM
Bob L.   Anyone that would do that to any animal is a si...   May 15 2014, 08:09 PM
billh1963   Anyone that would do that to any animal is a sick...   May 16 2014, 05:52 PM
mr914   Hmm.. Will have to post photo of universal cat car...   May 15 2014, 08:17 PM
injunmort   a little heat will cure the oxidation, just say...   May 15 2014, 08:31 PM
Bob L.   There was a recent thread about using vinegar to d...   May 15 2014, 09:38 PM
Mblizzard   Don't know if there are enough threads on thos...   May 16 2014, 06:06 PM
mr914   :beer1: Some very good ideas and some unique ones...   May 19 2014, 09:39 AM
stugray   Put it in an old crock pot full of vinegar and put...   May 19 2014, 10:42 AM
sixnotfour   I have had the same problem, and cut the stud...BT...   May 19 2014, 11:52 AM
mr914   I decided to disassemble the motor to see what con...   May 21 2014, 12:12 PM
Jon B   Case type 901/05 Sequence 6692 Case SN: 909442 Ni...   May 21 2014, 08:24 PM
mr914   Cams 901.105.109.01 901.105.110.01 Date stamped 2...   May 22 2014, 05:36 PM
toolguy   looks like you have Solex Cams. . Great for the s...   May 22 2014, 05:52 PM
Jon B   These were "Solex" cams for '67 engi...   May 22 2014, 06:20 PM
mr914   After cleaning some crud off of the end.... One s...   May 22 2014, 09:01 PM
Jon B   Sounds like it could be a fun motor. Would this be...   May 22 2014, 09:55 PM
Jon B   Sounds like it could be a fun motor. I built the e...   May 22 2014, 10:30 PM
gandalf_025   I'll throw another 2 cents into this. Not tha...   May 25 2014, 04:35 AM
mr914   Hmm..... Now this is a dilemma Sell or rebuild...   Jun 12 2014, 02:03 PM
mr914   Update: Had one of the cylinders stuck to the hea...   Jun 12 2014, 02:05 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:37 PM
