> RevWife's 914, Pulling a 914 back onto the road
Mikedrevguy
post May 19 2014, 09:34 AM
Post #21
Picked up a 76 2.0 for my better 1/2.
It's been off the road for the past -10 years. Motor spins freely and, reportedly, was rebuilt shortly before it was parked (which was due to physical limitations). Paint is heavily oxidized. Brakes were locked up, rotors rust covered. Car had been hit previously, and the resulting bondo has cracked pretty badly.
Interior is nice, seats have no tears or holes. Dash has a couple cracks, but nothing overly grotesque.
As I begin getting this back roadworthy,
Am pulling fuel tank to be cleaned out thoroughly. Replacing all fuel and vacuum lines. Changing oil and trans fluid.
Will go through brake system. See what's good. What's in need of replace or [email]repair.
My question: where can I go for a list of what pieces parts are compatible from year to year in the 914.
Interested in front and rear hoods, top, brake calipers -
Or more specifically, I've a line on a 71 running complete parts car- what will cross over between a 71 and a 76?
Thanks. I look forward to posting pics (when I get them and figure out how they work on this forum.
Rev.
Mikedrevguy   RevWife's 914   May 19 2014, 09:34 AM
Philip W.   :wttc: there are a few things that are not the s...   May 19 2014, 10:00 AM
green914   :wttc: there are a few things that are not the ...   May 19 2014, 11:03 AM
rick 918-S   :wttc:   May 19 2014, 12:26 PM
Mikedrevguy   Thanks for the welcome, and for the direction. Wh...   May 19 2014, 01:06 PM
jmill   :wttc: :ttiwwp:   May 19 2014, 01:07 PM
Mikedrevguy   Considering the offset- will changing the offset a...   May 19 2014, 01:34 PM
Jeff Bowlsby   First off...its incorrect to think of 914s as ...   May 19 2014, 01:45 PM
Dave_Darling   The tops are different, though if you swap over th...   May 19 2014, 04:18 PM
Mikedrevguy   http://www.914world.com/bbs2/uploads_offsite/i456....   May 19 2014, 07:19 PM
hndyhrr   okay, there are a couple tears. But I'm not sh...   May 19 2014, 08:33 PM
Mikedrevguy   welcome, i'm in central point. Thanks. Smal...   May 20 2014, 09:08 AM
Mikedrevguy   In effort to avoid the procrastinator's thread...   May 22 2014, 09:00 AM
Mikedrevguy   And rear rotors mic out at - 9.75mm Fronts - 10.4...   May 22 2014, 10:26 AM
Mikedrevguy   And rear rotors mic out at - 9.75mm Fronts - 10....   May 26 2014, 05:28 AM
bulitt   Some late cars equipped with smog stuff may have t...   May 22 2014, 10:47 AM
relentless   Welcome! I'm in Cave Junction. :driving:   May 22 2014, 01:39 PM
Mikedrevguy   Welcome! I'm in Cave Junction. :driving...   May 24 2014, 08:03 PM
Mikedrevguy   Found the fuel pump. What's the white box? htt...   May 24 2014, 08:02 PM
bdstone914   The white box is the fuel filter. That fuel sende...   May 24 2014, 08:11 PM
bdstone914   They do not get change often. You should be able t...   May 24 2014, 08:59 PM
Mikedrevguy   Thought it might be the filter, but, gosh, you thi...   May 24 2014, 08:47 PM
malcolm2   Thought it might be the filter, but, gosh, you th...   Jun 9 2014, 09:16 AM
Dave_Darling   They moved the pump up front in 74 i believe, may...   Jun 9 2014, 10:32 AM
76-914   They moved the pump up front in 74 i believe, ma...   Sep 24 2014, 06:00 PM
Mikedrevguy   Got fuel line from tank to tunnel out. No real big...   May 26 2014, 07:35 PM
jim_hoyland   Fuel Tank: there is a copper filter under inside t...   May 26 2014, 08:28 PM
Mikedrevguy   $200 to boil, acid wash, and line the tank. ...   May 27 2014, 09:45 PM
Mikedrevguy   Report from radiators shop: inside had some rust s...   May 29 2014, 06:16 AM
jim_hoyland   AA carries two socks (strainers); one for 70-74, a...   May 29 2014, 06:30 PM
Mikedrevguy   Thanks for the lead and the heads up. As far as p...   May 30 2014, 06:17 AM
hndyhrr   that would be the correct one.   May 30 2014, 06:50 AM
jim_hoyland   Thanks for the lead and the heads up. As far as ...   May 30 2014, 08:43 AM
Mikedrevguy   Picked Up the tank today. Looks good. Clean and se...   Jun 2 2014, 03:52 PM
Mikedrevguy   The fuel lines running through the tunnel, back in...   Jun 2 2014, 06:01 PM
Bob L.   The fuel lines running through the tunnel, back i...   Jun 2 2014, 06:43 PM
Mikedrevguy   Thanks, Bob. What would be the best way of replac...   Jun 2 2014, 07:26 PM
hndyhrr   Thanks, Bob. What would be the best way of repla...   Jun 2 2014, 07:45 PM
Mikedrevguy   Thanks, Reading up on the process from Pelican. Wh...   Jun 2 2014, 08:37 PM
Mikedrevguy   Diameter of lines: I've read of running both ...   Jun 2 2014, 09:34 PM
Mikedrevguy   Has the door latch mechanisms changed? Or are they...   Jun 9 2014, 07:48 AM
Mikedrevguy   Thanks, Malcolm. That's on my list to wrk on t...   Jun 9 2014, 09:58 AM
Mikedrevguy   Well then. Maybe I misunderstood- plastic lines ru...   Jun 9 2014, 04:13 PM
Dave_Darling   Well then. Maybe I misunderstood- plastic lines r...   Jun 9 2014, 08:40 PM
Mikedrevguy   Well, I put the project of replacing the fuel line...   Jun 9 2014, 07:45 PM
hndyhrr   Well, I put the project of replacing the fuel lin...   Jun 9 2014, 08:03 PM
Mikedrevguy   Dave, thanks for the Mage. That helps. Thanks for ...   Jun 9 2014, 09:27 PM
Mikedrevguy   got new battery, checked turn signals, flashers, h...   Jun 18 2014, 03:19 PM
Mikedrevguy   Getting closer to firing the motor. Drained oil-...   Jun 29 2014, 10:26 PM
Mikedrevguy   compression check this am revealed I've got 13...   Jun 30 2014, 03:02 PM
Mikedrevguy   and we've got ignition!!!! :Qa...   Jun 30 2014, 06:54 PM
Mikedrevguy   may be a shot in dark, but someone may be able to ...   Jul 5 2014, 03:49 PM
Mikedrevguy   verified that there is fuel getting through system...   Jul 5 2014, 04:12 PM
Mikedrevguy   relay question: found the relay box in the engin...   Jul 6 2014, 05:28 PM
Mikedrevguy   never mind; found it. Rennlist Techarticles had...   Jul 6 2014, 07:35 PM
PlantMan   never mind; found it. Rennlist Techarticles ha...   Jul 6 2014, 11:44 PM
Mikedrevguy   Thanks, PlantMan. I've had it running on start...   Jul 7 2014, 06:05 PM
Mikedrevguy   So, after a summer of other priorities got a fuel...   Sep 23 2014, 07:41 AM
malcolm2   So, after a summer of other priorities got a fue...   Sep 24 2014, 07:56 AM
Mikedrevguy   Thanks for the reply, Clark. have not had injecto...   Sep 24 2014, 04:36 PM
Elliot Cannon   It's too bad you can't run the fuel pump w...   Sep 24 2014, 06:03 PM
Dave_Darling   You can--either put a jumper wire where the pump r...   Sep 24 2014, 10:50 PM
Tbrown4x4   There are timer relays from companies such as Grai...   Sep 25 2014, 04:24 AM
Mikedrevguy   okay, got new fuel pump - bosch. confused on the ...   Oct 6 2014, 03:30 PM
Dave_Darling   Stock wires would be black with a red wire (power)...   Oct 6 2014, 06:22 PM
Mikedrevguy   Thanks. Confirmed the same independently.. Appreci...   Oct 6 2014, 06:34 PM
Dave_Darling   The 3/4 problems sound like mechanical ones with t...   Oct 7 2014, 09:13 AM
Mikedrevguy   Firing on all cylinders. Turns out, the fuel pump ...   Oct 20 2014, 02:52 PM
Mikedrevguy   Replaced all vacuum and air lines. The vacuum line...   Oct 20 2014, 04:35 PM
Mikedrevguy   Wow. Has it been so long?? Lots changed. HPMX 44 i...   Nov 8 2017, 10:21 AM
Mikedrevguy   http://www.914world.com/bbs2/uploads_offsite/www.t...   Nov 8 2017, 10:29 AM
Mikedrevguy   http://www.914world.com/bbs2/uploads_offsite/www.t...   Nov 15 2017, 09:22 AM
Mueller   I dig the stripes...   Nov 15 2017, 09:58 AM
Mikedrevguy   Thanks. A product of KingHat Pinstriping   Nov 15 2017, 03:45 PM
erwan914   or can buy the aluminum rod ? Erwan   Nov 23 2017, 03:20 AM
Mikedrevguy   We had engine lid installed. Still have tape on, a...   Dec 18 2017, 08:34 PM
Mikedrevguy   Yeasterday wos the mirrors. Today, the door panel...   Dec 22 2017, 06:48 PM
Mikedrevguy   Sail trim on. Rain tray installed. Only thing lef...   Dec 22 2017, 09:10 PM
Mikedrevguy   Also, mounted 205/60/15 all around. Preliminary in...   Dec 23 2017, 12:25 PM
ConeDodger   So, let me get this straight? Your wife daily driv...   Dec 24 2017, 01:37 PM
Mikedrevguy   Yup, I think RevWfe is pretty special, too. Thanks...   Dec 24 2017, 02:04 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:53 PM
