Engine Bay Water Drain Hose? |
lsintampa |
May 22 2014, 03:37 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
I can't seem to locate any source for the water drain hoses (those in the engine bay on the left and right side - that attach to the funnels that collect water from the big water drip pan).
Assume they are NLA. Any aftermarket stuff or is it just old used stock? I guess I can do my own hose connections - local hardware store route, I just thought if they were around, it may be nice to add. One side is fine (pass), the driver side is busted up. Any sources for decent replacements? Thanks, Len |
bdstone914 |
May 22 2014, 03:44 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I can't seem to locate any source for the water drain hoses (those in the engine bay on the left and right side - that attach to the funnels that collect water from the big water drip pan). Assume they are NLA. Any aftermarket stuff or is it just old used stock? I guess I can do my own hose connections - local hardware store route, I just thought if they were around, it may be nice to add. One side is fine (pass), the driver side is busted up. Any sources for decent replacements? Thanks, Len If you go to the garden section of a local Lowes or Home Depot they carry irrigation tubing in 20 foot lenghts for $20. It is 1" id compared to the OE 25mm. Works great and the same tubing as the front blower box drains. Only visible difference is the ridges are a spiral and the original are rings. So the clamp goes over a ridge. |
Lo-Fi Version | Time is now: 17th May 2024 - 01:28 AM |
