Steering Column Swap, Switch cluster and key |
eric914 |
Jan 16 2005, 12:02 PM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
Can an early (1974) column assembly be put into a 1976 car? From a parts car I have a good switch assembly that has the steel outer case. Can this be used on a 1976 column?
Also, any tips on removing the housings once the socket head bolt has been removed? Thanks |
eric914 |
Jan 16 2005, 02:58 PM
older style
eric914 |
Newer style
eric914 |
Jan 16 2005, 02:59 PM
Older style switch assy
Jan 16 2005, 03:04 PM
Resident German Group: Admin Posts: 41,608 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
'74 to '76 should be easy. i swapped a '74 in a '70 which was a royal PITA ... as long as the mounting plate (with the 4 bolt holes) has the same size/shape/spacing, you'll be fine. i don't think the wiring changed from '74 to '76 so the connectors should be the same as well. to remove the housing, you have to remove the 2 clips that hold in the shaft. dunno what they're called, but you need a special tool to squeeze them for removal. once those are gone, the shaft will slide out. when re-installing, make sure you got a good metal "sleeve" that will give you a snugg fit of the shaft inside the bearing. i really only see major problems if you try to mix/match early and late columns. that would be pre '72 and '72+ because everything is different between those. again, '74 to '76 should be fine ... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy |
jd74914 |
Jan 16 2005, 03:05 PM
Jeeez, I thought everything from '73 on was the same. I could be wrong though. I think the swap would work (Disclaimer: I've never done one)
Jan 16 2005, 03:24 PM
that basic hardware is the same, mounting plate, shaft etc. what changed was the design of the lock and the housing .... on pre '72 cars, even the length of the shaft and the angle the steering column is mounted are different. you'll have to do some serious grinding and (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) to fit a late column on a early car. you even need to regrind the grooves on the shaft where the universal joint mounts ... (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) Andy |
Rhodes71/914 |
Jan 16 2005, 04:57 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Wish I would have known about the pre '72 being different from the later. I have a great later column that I was going to put in my 71, went to pull the one out of the 71 and noticed that the bolting was completely diff.
Anyone have a good '71 column they want to trade for a later one. No key though. |
jwalters |
Jan 16 2005, 06:21 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) I wonder ifn this is peculiar to certain years?? My 72 had a bad tumbler and shaft--I raped the one outta my donor 74 and it went right in--same harness connectors, mounting..hmmmmmm...maybe I should go scrutinize the chassis numbers----where are all of them???? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Jan 16 2005, 11:49 PM
'72 - '74 are the same, '75 and '76 are different but will fit '72 - '74, '70 and '71 are completely different and won't fit any '72+ or vice versa (unless you do some major (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) and change the wire harness) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
eric914 |
Jan 18 2005, 09:37 AM
Thanks to all who responded.
I have completed the swap and once I realized I needed to have a key in the switch to release the lock (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) it went well. The new 74 piece replaced the 76 piece perfectly. In my opinion the steel outer housing of the 74 is nicer than the plastic housing of the 75-76. All lights and turn signal functions now seem to work. Now.....onto rebuilding the front suspension. Eric |
Rusty |
Jan 18 2005, 11:53 AM
Good job, Eric! Good luck with the front suspension! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
ClayPerrine |
Jan 18 2005, 11:59 AM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Wish I had been around to see this post sooner.. We did this to Yoder's car a few years ago. We were trying to fix the "haunted horn" syndrome that he has. It didn't work.
The fun part was that Yoder couldn't figure out how to start the car afterwords. He had to push on the key to get it to turn. The 75/76 lock just turns. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) |
Rockaria |
Jan 18 2005, 12:06 PM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
I've done it as well. It is a direct swap. |
Lo-Fi Version | Time is now: 1st May 2024 - 07:41 AM |
