carb rainshields, any ideas for dual 44idf ? |
Triaddave |
Jan 16 2005, 03:22 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
now that i made the two grill hood, the problem now is how to keep the carbs dry. the wife suggested mini meat loaf pans,but the corners will come in contact with the linkage. i can modify the pans (and have them powder coated) but what would be ideal is some kind of round cover like the 914/6. i thought about the tupper ware section, but...any other options out there?
Aaron Cox |
Jan 16 2005, 03:23 PM
i just put MORPHENSPECTRA's IDF rainshields on my car. kept the carbs dry during the super 15 day rain...
see the resources section of this site |
Aaron Cox |
Jan 16 2005, 03:24 PM
Voila~
(IMG:http://www.914world.com/bbs2/uploads/post-4-1097774063.jpg) BUT- i had to lift my shields 3/4 (aluminum spacers and taller studs) inch up so they would clear the cb performance linkage.... |
machina |
Jan 16 2005, 03:31 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
yup,
mine fit straight away...well crafted Attached image(s) |
Triaddave |
Jan 16 2005, 03:32 PM
perfect! i'll check it out. it beats the heck out of the tupperware idea too. what is the price tag?( haven't seen the link yet. and thanks for the quick response
Aaron Cox |
Jan 16 2005, 03:35 PM
40 bucks or so....
Dave- i have the exact same setup as you : CB linkage and tall manifolds.. my right sode onw interefered with the trunk torsion bars, and they both sat too low to clear the pivot post on the linkage (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) what did you do differently? |
Triaddave |
Jan 16 2005, 03:43 PM
i like the way dave's car is set up as well. in my case i'll be using the triad linkage and i think i will not have that issue. i have the tall manifolds as well.i do not have the air filters or the plates to mount the filter with yet. this should work out great for me. thanks to both of you.
Triaddave |
Jan 16 2005, 04:00 PM
i came up empty handed at the resource page but i'll try to find them on the internet. any other leads, like a site name?
Aaron Cox |
Jan 16 2005, 04:19 PM
click on "914 forums" then go to "resources products..etc" and look for morphenspectra's posts on "914 appearance and performance" ill get a link.... 914 Appearance and Performance - go to page 2/3 This post has been edited by Aaron Cox: Jan 16 2005, 04:20 PM |
machina |
Jan 16 2005, 04:32 PM
we ain't got no stinkin torsion bars (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
i cut most of that stuff away long ago... |
Aaron Cox |
Jan 16 2005, 04:34 PM
thats what i figured.... but did you raise the hats at all to clear the upright "pillar" where the crossbar mounts? also david, can you take a pic of where the aurora spark plug wires go into the tin/head? and a closer pic of the mallory and oil pressure sending unit please. much appreciated... Aaron |
machina |
Jan 16 2005, 04:39 PM
more after dinner, on the grille now. (IMG:http://www.914world.com/bbs2/html/emoticons/chowtime.gif)
didn't have to raise them, just fit ok. i did put them on top of the alu plates so maybe that's how i got the extra clearance. Attached image(s) |
Aaron Cox |
Jan 16 2005, 04:45 PM
i did put mine on top of them too.../ thats really wierd (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) thanks for that pic (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
machina |
Jan 16 2005, 05:34 PM
the rest...
Attached thumbnail(s) |
Aaron Cox |
Jan 16 2005, 06:03 PM
david, thank you.... did you run the ceramic wire extenders or just the wires all the way to the plugs?
machina |
Jan 17 2005, 07:10 AM
wires to plugs
JoeSharp |
Jan 17 2005, 01:14 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Rain hats, I chose a less expensive and yet much more tastful route. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Joe Attached image(s) |
Aaron Cox |
Jan 17 2005, 01:16 PM
hahahahahha too funny. at least get the teflon coated bread tins at walmart! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
machina |
Jan 17 2005, 01:19 PM
mmmmmmmm, jiffy pop (IMG:http://www.914world.com/bbs2/html/emoticons/chowtime.gif)
Lo-Fi Version | Time is now: 18th May 2024 - 08:50 AM |
