Eyebrow mounts |
Eyebrow mounts |
mrholland2 |
May 28 2014, 06:46 PM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Okay,
What mounts the eyebrows to the body of the car and where can I get them and so forth? Thanks!!! (IMG:style_emoticons/default/confused24.gif) |
Jeffs9146 |
May 28 2014, 06:51 PM
speed metal army |
May 28 2014, 09:14 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Yep! 914Rubber has the goods. (IMG:style_emoticons/default/aktion035.gif)
Mikey914 |
May 28 2014, 11:15 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
They are a pain to mount, I did make mine about 10 durometer softer than OEM, this makes them easier to get in.
http://www.shop.914rubber.com/914-Eyebrow-...of-6-914EYE.htm |
mrholland2 |
May 29 2014, 05:28 PM
They are a pain to mount, I did make mine about 10 durometer softer than OEM, this makes them easier to get in. http://www.shop.914rubber.com/914-Eyebrow-...of-6-914EYE.htm you got my order last night! (IMG:style_emoticons/default/smile.gif) |
57lincolnman |
May 29 2014, 07:57 PM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
They are a pain to mount, I did make mine about 10 durometer softer than OEM, this makes them easier to get in. http://www.shop.914rubber.com/914-Eyebrow-...of-6-914EYE.htm AutoAtlanta has them too. You will $5.50 a piece over there for these little gems. Six will set you back about $30. They are very supple and with a spot of WD-40 they slide easily. The eyebrows fit in nicely and snug with no movement. Now if I could just adjust those things. Unfortunately that holes are pre-drilled and presume that everything else lines up perfectly too. |
Lo-Fi Version | Time is now: 18th May 2024 - 03:04 AM |
