QUOTE(Mikey914 @ May 28 2014, 09:15 PM)
They are a pain to mount, I did make mine about 10 durometer softer than OEM, this makes them easier to get in.
http://www.shop.914rubber.com/914-Eyebrow-...of-6-914EYE.htmAutoAtlanta has them too. You will $5.50 a piece over there for these little gems. Six will set you back about $30. They are very supple and with a spot of WD-40 they slide easily. The eyebrows fit in nicely and snug with no movement. Now if I could just adjust those things. Unfortunately that holes are pre-drilled and presume that everything else lines up perfectly too.
