Stripped Stud, Where Can I Buy New??? |
d7n7master |
Jan 16 2005, 05:39 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
Hi All,
I need to replace this stud with a new stud that is at least 1/4 inch or so longer than this one. The rocker assy's are shimmed. So I assume that's why the stud is too short to have sufficient thread protrusion with the rocker assy installed. Attached image(s) |
d7n7master |
Jan 16 2005, 05:41 PM
Threads in the head seem OK...
Should I just chase 'em & re-install a new stud??? Heli-Coil??? Or... Thanx, Gary Attached image(s) |
Mark Henry |
Jan 16 2005, 06:15 PM
Fat performance has 8mm studs for the rockers...I think they're a bit longer.
d7n7master |
Jan 16 2005, 06:18 PM
Awesome! Thanks
Fat it is... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
d7n7master |
Jan 16 2005, 09:00 PM
AA's good for somethin' - I found the stud p/n. WooHoo (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
DJsRepS |
Jan 17 2005, 05:18 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
You could try one of the same and use lok tite on the head threads Seat it down into position and then back off it a little. 1.5 turns back out to raise it a little. It's not like a rod bolt taking a pounding.
Walter |
Jan 17 2005, 07:35 AM
Member Group: Members Posts: 70 Joined: 10-August 04 From: The Netherlands, Europe Member No.: 2,499 |
Are you sure its M8 that threads into the head? IIRC, the nuts are M7 (which is rare, even in Europe) and the thread into the head is M9 , which is also a rare size... Helicoils will very therefore probably be non-existant for those threads. I use 1,5mm shims on the same heads with P-swivelfeet and still am able to fully screw on the nut with the 7mm washer underneath. Maybe better to try use the original item if the threads are ok. regards, Walter |
Mark Henry |
Jan 17 2005, 08:02 AM
The ones Fat sell are M9 (or is it M10 with an odd pitch?)on the head and M8 on the stud. Gets rid of the sucky M7 nuts. Then you can use an 8mm nut or even better the M8 with the 15mm wrench size. The Fat ones are made for high performance T4 heads.
Up here (in Canada at least) you can get them at Home Depot.... |
Walter |
Jan 17 2005, 08:43 AM
Thanks for the extra info on the FAT studs Mark!
The M7 nuts are not available here at home depot warehouses (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) , but sometimes at bicycle stores, which use more often the M7 thread. You know what bicycles are don't you? (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) |
d7n7master |
Jan 21 2005, 09:49 AM
I KNEW BETTER & EFFIN' DID IT ANYWAY!!! Ahhhh!!!
Last Sunday I ordered the studs from AA. I thought they could handle a order for a couple of studs, washers & nuts. Their website showed the parts as "available". I called to check on my order last nite. They said they were waiting on the studs to come in to complete my order. I said - your website showed the studs as available when I placed my order. She said they are available & they are on order. Probably be delivered within a week. Damn. That's B.S!!! AA can (IMG:http://www.914world.com/bbs2/html/emoticons/pissoff.gif) I got your available right here (IMG:http://www.914world.com/bbs2/html/emoticons/chair.gif) |
DuckRyder |
Jan 21 2005, 10:46 AM
Avatars Mode: OFF because of the recalcitrant few. Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
The bird has those.
In fact, if I can find it I think I have an extra.. |
Type 4 |
Jan 21 2005, 12:02 PM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
I could have supplied those for you and I am just down the road.
d7n7master |
Jan 21 2005, 12:43 PM
Thanks Type4! I'm up for it. I 'don't want to wait another week or more for AA to someday deliver.
PM me with your# & let's make a deal! Thanks, Gary |
d7n7master |
Jan 25 2005, 12:10 PM
Well, it's now Jan. 25th & I STILL don't have my studs from AA... (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif)
Thatz it. I'll NEVER puchase from AA again. I should have known better. Two years ago I ordered a front air dam from AA. I waited for 3 months... then amazingly enough, it finally arrived. I'm gonna have to call FAT today. 2 bad FAT doesn't have a parts order web page. |
skline |
Jan 25 2005, 01:31 PM
Didnt you get them from Steve? He is just down around the corner or so from me.
Lo-Fi Version | Time is now: 17th May 2024 - 12:57 PM |
