Seat adjustment, Am I missing something? |
-JR- |
Jan 16 2005, 07:55 PM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
I got in my 914 for the first time yesterday and I've been trying to figure out how to adjust the dang drivers seat forwards and backwards...
I'm not sure what the pull up handle does on the side of the seat, but it doesn't seem to want to make it move. The passenger seat has a handle that sticks out the front from one of the sides of the seat track, but the drivers side has no handles or nothing out the front of it. Thanks! -JR- |
vortrex |
Jan 16 2005, 07:58 PM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
it commonly breaks off, so I bet your drivers side did.
-JR- |
Jan 16 2005, 07:59 PM
So does that mean there is no way to move or remove the seat?
Also, what does the side handle opperate? -JR- |
jim912928 |
Jan 16 2005, 08:01 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Ok..the handle on the side is for seat rake/angle. When you pull that up your seat will be able to tilt back/forth. The adjustment for forward/backward is on the front of the seat. There should have been a handle there with like a big O to grab onto. These break off very easily. If yours is missing it is obviously broken off (sounds like your passenger side has it?)?. If this is the case get a flashlight...look under the seat from the front...find where it is broken off and depending on where/how it broke off you might be able to use one of your handy tools to pull the adjuster and move the set. Might have to 2-person it if it is broken way far back.
You'll understand once you look under the seat on both sides along the rails. Then go to the classifieds and ask if anybody has one they could part with!. |
jim912928 |
Jan 16 2005, 08:03 PM
also note:..if you pull up on the side handle and set the rake as far back as you can (the bottom will lift) you'll be able to see under the seat better.
-JR- |
Jan 16 2005, 08:05 PM
Thanks for the notes!
I've looked very hard at the seat track already and it's just a cave! There is no sign of there ever being a handle arm ever being in place. RRRR!!! The seat "rake", does it tilt up at the front and hinge from the back? Thanks! |
tracks914 |
Jan 16 2005, 08:27 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Yes it does. As for the "tunnel" you might be looking at the wrong rail. If the seat was getting hard to move, the PO might have tugged to hard on the handle thinking that was the reason for it not moving. Worse come to worse, you can get under the seat and unbolt it, take it out, clean it up and replace the handle. |
r_towle |
Jan 16 2005, 08:31 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
On the drivers side seat look under the front, look on I believe the side closest to the shifter, you will see a space between the top rail (bolted to the seat) and the bottom rail (bolted to the car). This space is approx 1/2 in maybe more like 10 mm.
If you look at the one remaining on the passenger side you will see the action is you pull up the handle, this pulls up a bar that is pivoted at the rear of the seat rail. This bar has a few square posts sticking out of the bottom that index into the holes in the seat track. If you slide a long thin flat screwdriver in the seat rails, under the bar that is supposed to have the handle on it, you will be able to pry up this bar and release the seat to go forward and back. If you pull up on the passenger seat and slide it all the way forward you might be able to see how it works better. If you want to take out the seat, you will only be able to go about 75% of the way then you hit a stopper...this is on the opposite rail from the handle. This one requires a screw driver to release the seat all the way. Rich |
Bleyseng |
Jan 16 2005, 09:28 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
This is another spot where the rust monster strikes. Once the seat rails rust, you can't muve them forwards or backwards. Then some moron thinks that if you pull "harder" on the handle this will help the seat move. Nope, you just get a handle in your hand.
Pull the whole seat assembly out and take it apart and clean and lube it. Should slide smoothly. Geoff |
Rhodes71/914 |
Jan 16 2005, 11:19 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
When I got my 914 the handle was broken off. After some help here I was able to locate where the handle had broken off and could move it up with my hand. Still no action on moving the seat.
I finally figured out what Geoff mentioned, my rails were rusted. After much of the afternoon of PB blaster and a hammer and a 2x4 I got a little movement. Then I was able to keep working it back and forth and got it freed up. It was a bitch, good luck. Sean |
DJsRepS |
Jan 17 2005, 05:27 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
Once you do find the adjuster lever on the right side rail adj the seat all the way foward then get out kneal beside the seat and lift the lever again and continue pushing the seat foward by hand it will slide off the rails and out of the car. Easy tool free seat removal. Then you can see what to do with the broken handle and clean and lube the tracks. I think you can swap seats at that point or at least the broken adjuster handle.
jd74914 |
Jan 17 2005, 08:57 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I'd just take off the seat altogether. I did this in a few minutes and was then able to clean the seat rails and adjustment mechanism. Works great now.
Lo-Fi Version | Time is now: 24th May 2024 - 10:03 PM |
