Oil Pressure Transducer, What the..... |
martinef1963 |
Jan 17 2005, 11:00 AM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
Happy MLK day to all you guys/gals out there...
Can someone explain what this transducer thingamajigi does? Mine looks like it's covered in oil and so is the electrical connection that comes off of it. thanks - one of the newer guys on the block. (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
DNHunt |
Jan 17 2005, 11:45 AM
If it is a one wire job it powers the green oil idiot light in the left hand gauge. If you turn the power on you should see a red alternator light and a green oil pressure light. Both should go out shortly after startup. 2 wire sensors are after market and are usually mounted on a flexible hose. They power the same green light and an oil pressure gauge.
Dave |
martinef1963 |
Jan 17 2005, 12:52 PM
thanks - now for another question, same subject - why is it that it gets so oily? I understand that it drives my idiot light, but I pressure cleaned the engine and it is clean - all for that sensor?
Is it normal? Maybe I sould get a wrench out and tighten that sucker up. thanks, (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) |
jwalters |
Jan 17 2005, 01:43 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Hey martin--I live right off of 595 and Flamingo---where are you at?? PM me if you prefer---I am active duty coast guard and can help you with any problems you may encounter---you should see my baby right now--nothing but the tub!!!
Cheers! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 12:23 AM |
