Can someone explain what this transducer thingamajigi does? Mine looks like it's covered in oil and so is the electrical connection that comes off of it.
thanks - one of the newer guys on the block.
DNHunt
Jan 17 2005, 11:45 AM
If it is a one wire job it powers the green oil idiot light in the left hand gauge. If you turn the power on you should see a red alternator light and a green oil pressure light. Both should go out shortly after startup. 2 wire sensors are after market and are usually mounted on a flexible hose. They power the same green light and an oil pressure gauge.
Dave
martinef1963
Jan 17 2005, 12:52 PM
thanks - now for another question, same subject - why is it that it gets so oily? I understand that it drives my idiot light, but I pressure cleaned the engine and it is clean - all for that sensor?
Is it normal? Maybe I sould get a wrench out and tighten that sucker up.
thanks,
jwalters
Jan 17 2005, 01:43 PM
Hey martin--I live right off of 595 and Flamingo---where are you at?? PM me if you prefer---I am active duty coast guard and can help you with any problems you may encounter---you should see my baby right now--nothing but the tub!!!
Cheers!
