Question: what oil temps do you see on your non-stock 6?, 2.4 to be exact, with no oil cooler up front |
naro914 |
Jun 10 2014, 03:37 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
For anyone that has a 2.4 or bigger /6 engine that does NOT have a front oil cooler, what kind of oil temps are you seeing under normal driving?
I guess the follow up (or leading question) should be...is a front oil cooler mandatory for this engine in a 914? Engine is stock, nothing extra special. Engine is carb'd and AFR seems pretty good (mid 12's at normal running) This is a buddy of mine's. Our cars have always had front oil coolers and run very cool, so I'm not familiar with the affect of NOT having the front cooler on it. But his is running just above 100 degrees C (212 deg F) which seems a bit high. He does have a small cooler with a fan in the back, above the axle area. thoughts/ Comments? Suggestions? Thanks |
Jun 10 2014, 03:52 PM
Resident German Group: Admin Posts: 41,642 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Mine runs too cool for my liking.
My thermostat opens somewhere around 180 and unless i get stuck in traffic on a 100+ day, my temps never go over 200. 95% of the time they stay right at 180 ... (IMG:style_emoticons/default/popcorn[1].gif) PS: 3.6L, no engine cooler, large front mounted cooler, no fans. PPS: A stock 2.4L should be fine with the stock engine mounted cooler. I know of several stock 3.2L here in CA that only run the engine cooler, without any problems (street driving only). |
naro914 |
Jun 10 2014, 04:40 PM
billh1963 |
Jun 10 2014, 05:06 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Not quite a 2.4L but my 2.0L (bumped up to 2.2 running E cams and triple Webers) runs around 200 to 210 at interstate speeds in 80 to 90 degree weather. At slower speeds it will drop down to 190-200. I do not have an external cooler.
I've done a lot of internet "research" and 212 seems to be perfectly acceptable. If it bothers your friend he can consider an external cooler. |
jmill |
Jun 10 2014, 05:24 PM
Does your friend have a T, E or S engine?
(IMG:style_emoticons/default/popcorn[1].gif) I have a 2.2T and a 2.4 T and I'm debating whether or not to go with the front cooler. |
ClayPerrine |
Jun 10 2014, 05:47 PM
Life's been good to me so far..... Group: Admin Posts: 15,469 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Without an external oil cooler, my 2.4S motor will run up to 250 in the Texas summer heat. I don't like that.
With the 911 Carrera cooler, it runs about 210, which is good. I mounted the cooler in the left rear corner where it gets air from under the fender. |
patssle |
Jun 10 2014, 05:52 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I'm doing a 3.0L conversion and my research really goes either way...it seems a good 50/50 split of opinions to do a secondary oil cooler or not. The rule always seemed to be 2.7L or higher but there is plenty of opinion.
buck toenges |
Jun 10 2014, 06:36 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
My 3.2 runs close to 250 degrees in the heat. Way to high for me. I probably need to get a front cooler. What did you do andy to get your 3.6 to be so cool?
Buck |
tomeric914 |
Jun 10 2014, 06:58 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
I saw 260+ deg F at the track with a 12 x 12 fan assisted oil cooler back by the transmission. It was relocated to the front about 3 years ago with a 180 deg F Mocal oil thermostat and ran too cool. I switched to a 200 deg F thermostat over the winter and now it runs between 180-200 deg F on the street or track.
naro914 |
Jun 10 2014, 07:15 PM
So he tried registering on here and wanted to post, but got an error saying he does not have authorization to post!!
Andy??? |
Wdunster |
Jun 10 2014, 07:22 PM
Panel beater Group: Members Posts: 172 Joined: 10-June 14 From: Monroe,nc Member No.: 17,469 Region Association: South East States |
Thanks for thin put guys! I am over cautious due to issues I have in the past. I am not as comfortable with 212 deg to 220. My 2.4 is e cams 9.5:1 compression with "s" heads. Zenith carbs.
I even borrowed Bob's sport exhaust thinking my exhausted is restricted. Sounds and runs better. |
Wdunster |
Jun 10 2014, 07:23 PM
That would be input. Auto correct. Gotta love it!
Jun 10 2014, 07:44 PM
What did you do andy to get your 3.6 to be so cool? Dunno, it's always been like that. I got a large front mounted cooler that is shrouded, air goes out the top through the hood. My guess is that the large cooler plus the long lines are enough of a heat-sink to work well even in stop/go traffic. The hottest i have ever seen was 220ish and that was after getting stuck in traffic in 100+ weather after some 500 miles through the desert ... (IMG:style_emoticons/default/popcorn[1].gif) |
mskala |
Jun 10 2014, 07:51 PM
Thanks for thin put guys! I am over cautious due to issues I have in the past. I am not as comfortable with 212 deg to 220. My 2.4 is e cams 9.5:1 compression with "s" heads. Zenith carbs. I even borrowed Bob's sport exhaust thinking my exhausted is restricted. Sounds and runs better. I forget the numerical temp since the stupid gauge doesn't want to print them in the visible area, but on my 2.2E it stays to the left of vertical, and quite a bit left while driving around casually. Maybe clean your oil cooler? Also you can take the thermostat out (one of the few things that's easy in the 914 but hard in the 911 (IMG:style_emoticons/default/biggrin.gif) ) and put it in a pan of water on the stove, use a meat thermometer and heat up kinda slowly and see that it opens at 83C. |
Wdunster |
Jun 10 2014, 07:56 PM
Thanks Mark
3000 miles on a fresh complete rebuild. I have replaced the thermostat but will definitely recheck this one. |
Lo-Fi Version | Time is now: 18th May 2024 - 08:34 AM |
