BUILD-OFF CHALLENGE: Finn's '75 2.0l FI 914 build, October updated! |
dudzy's914 |
Jun 10 2014, 05:19 PM
The youngin' Group: Members Posts: 271 Joined: 21-December 13 From: Hatfield, MA Member No.: 16,784 Region Association: North East States |
Hey, gang! So here's the deal; my name is Finn, and I'm 14 years old (that doesn't really matter), I have been reading 914World and learning all sorts of skills for about 3 years now. I bought my first 914 in mid 2012, a '74 1.8l. It wasn't running, I knew there was an engine rebuild in the future. But as I was disassembling, I found some unwanted rust issues out of my budget at the time (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/confused24.gif) . So this spring I came across a Black '75 2.0l FI. All body work was already done, brand new interior...
So, this (by the way, a very nice guy) started this project about 8 years ago, he had all the body work done, reupulstered interior, he bought everything you would need to build a new 914. All I needed was a battery and this car purred so smoothly it is unbelievable. My dad, has owned busses, Beetles, Ghias, 914s, a lot of air cooled wonders, so he knows a lot about them. He has/is helping me learn, he already taught me a ton, enough to feel confident to go out to the barn and make progress by myself. Thanks a lot, your the BEST DAD! My plan is to fix the small remaining little bits of work; welding e-brake pivot plate, seat belt attachment bolt, center console wiring, recover dash. then I will shoot it with gloss black Plasti-Dip(to preserve until I can afford a quality paint job) and reassemble. Since I got a lot of extra parts, I will be selling some. I will post a link in the classifieds to ebay, where I will be selling them. (as for the '74, that will be a father-son race car project.) By the way, I am paying for everything. Including the gas to pick it up. I will keep you all updated as the build progresses. And ask a few questions:) I'll post better pictures later |
ChrisFoley |
Jun 12 2014, 10:31 AM
I am Tangerine Racing Group: Members Posts: 7,924 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The correct threads for seatbelt mounting is 7/16-20. (7/16-20 and M11 x 1.25 are virtually identical btw)
Just buy some nuts at the hardware store, weld them onto small plates with a 1/2" hole, and weld the plates onto the surface after cutting a hole big enough for the nut to go inside. That's easier than other methods and just as effective, as long as the added thickness doesn't create interference with something else. |
dudzy's914 |
Jun 12 2014, 10:56 AM
The correct threads for seatbelt mounting is 7/16-20. (7/16-20 and M11 x 1.25 are virtually identical btw) Just buy some nuts at the hardware store, weld them onto small plates with a 1/2" hole, and weld the plates onto the surface after cutting a hole big enough for the nut to go inside. That's easier than other methods and just as effective, as long as the added thickness doesn't create interference with something else. I have been searching for the specs since the were no nuts or bolt for the bottom attachment. Thanks a lot Chris! |
Lo-Fi Version | Time is now: 12th May 2024 - 02:33 PM |
