NEW 2.0L Rods..We need buyers to make this happen, Let Jake know if you want a set or 2 ! |
Dominic |
Jan 17 2005, 08:53 PM
Dominic Group: Members Posts: 991 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
http://shoptalkforums.com/viewtopic.php?t=80648
Read the whole thread if you are interested in new and improved....(400 grams lighter) 2.0L rods for your 914. Jake is talking about $280.00 a set, but it won't happen unless he gets enough buyers lined up. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) For that price you could afford to put a set on the shelf and keep them for the next rebuild. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I'm buying at least 2 sets....who else wants to see this happen ? (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
rhodyguy |
Jan 17 2005, 09:13 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,063 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
my goal is eventually put together a 2056, for a number of reasons. they would have to be set up for the 71mm stroke. do you think the performance gain will be worth the cost? i'm waiting to see what will be available and what items are going to cost when jake's store is open.
kevin |
Jake Raby |
Jan 17 2005, 09:31 PM
If it wasn't worth the cost I would not be attempting this..
The weakest link in a TIV is those heavy ass rods that cost 140 bucks just to outfit with better bolts. These rods are a 100% stock replacement, just 400 grams lighter with a 300% stronger bolt. I have to buy 500 rods to get them made at all, and trust me, thats a chunk of moolah! These rods selling for 280 bucks a set are cheaper than a rebuilt set of upgraded stock rods, those run 325.00 and are no where near as strong! I have ran rods with these same characteristics in 300+ HP Turbo engines, with just using an upgraded bolts. |
rhodyguy |
Jan 17 2005, 10:19 PM
tempted. how's it going to work? pay upfront and wait, comitt and you wait? will these be a billet item or cast?
kevin |
Jake Raby |
Jan 17 2005, 10:26 PM
The rods are an H Beam design, totally forged rod similar in design to a Carrillo.
I don't want ANY money till I have atleast buyers for 50 sets, then I'll get the money and we'll have rods in about a month.. |
ablose58 |
Jan 17 2005, 11:29 PM
rust never sleeps Group: Members Posts: 584 Joined: 6-December 03 From: port orchard,wa. Member No.: 1,422 |
I am in for a set (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif)
McMark |
Jan 18 2005, 02:15 AM
I'm in for a set. 500 is only 125 sets. Heh heh heh, I said only. (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
Jake Raby |
Jan 18 2005, 02:48 AM
Yeah...... Its only more money than I actually pocketed all last year for those 125 sets, even if I pre sell 50 of them!!
Unless you are the owner of a hack shop that cranks engines out left and right this isn't a very lucrative business. |
Rick_Eberle |
Jan 18 2005, 03:27 AM
Member Group: Members Posts: 390 Joined: 14-January 04 From: Geelong, Australia Member No.: 1,558 |
Can these rods be used with a longer stroke than 71mm??? Or are they too short?I'm thinking 74-76mm.
Rick |
Walter |
Jan 18 2005, 07:10 AM
Member Group: Members Posts: 70 Joined: 10-August 04 From: The Netherlands, Europe Member No.: 2,499 |
Hi Jake,
Is it a 24mm (stock) or 22mm piston pin? (strange nobody asked before) Thanks, Walter |
Mark Henry |
Jan 18 2005, 07:53 AM
Good question Walter! (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
Jake Raby |
Jan 18 2005, 09:16 AM
THESE PARTICULAR RODS ARE AN EXACT COPY OF THE 2.0 TYPE 4 ROD!!!!!
SAME LENGTH SAME BIG END SAME SMALL END BUT, 400 grams lighter, H Beam style and equipped with 8740 ARP bolts as standard equipment. In my opinion the standard length 2.0 rod should be avoided when stroking due to the piston velocities that they create. Sure it can be used, but it will not have the efficiency or rev capability as a proper length rod. When stroking we totally get away from the 2.0 rod journal any way simply because the only bearing available for it is a Bi- Metal OEM unit that can't take alot of point load due to its material and diameter. When stroking we add rod length to correct the rod ratio AND change journal characteristics to allow the use of a better bearing. Hell, my 2316 engines use the EXACT same bearing that NASCAR runs! We need a rod thats a stock 2.0 replacements- Thats what these are! A set of 2.0 cores costs as much as these do not including having them just rebuilt to stock specs! I can make any rod, any length, just have to do 500 the same at one pop. I already have my own rods made for my 2270 and 2316 combos..... This is the reason I have been so cautious about going forward with these, because I won't use many of them myself simply because almost everything we build is a stroker. |
Walter |
Jan 18 2005, 09:23 AM
Thanks Jake!
I was afraid you were going to say 22mm pin because so many aftermarket manufactorers use a piston with 22mm small end pin. Bushing 24mm to 22mm is of course much more easy than the other way around (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) so they will still be more universal that way! I still have a nice set of 6000km used JE's 96mm/barrels with the 24mm pin, so I am pleased to hear this and am in for a set also if they will be available within reasonable time (say 6 months or so) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Thanks, Walter |
Jake Raby |
Jan 18 2005, 09:32 AM
I don't use a 22 pin till we add stroke......
Then everything gets a 22mm pin. I just need enough people to commit to buy them. So far I only have 18 takers and MUST have 50 to do the deal. |
type11969 |
Jan 18 2005, 09:35 AM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
jake, how would one go about getting on the list?
-Chris |
Jake Raby |
Jan 18 2005, 03:37 PM
I am setting up an email account just for it...
william harris |
Jan 18 2005, 05:01 PM
914 Restorer Group: Members Posts: 1,459 Joined: 9-January 04 From: Hamilton, MA Member No.: 1,539 |
Now if I could get somebody to commit to build my motor, I might be interested. Jake is way too busy. No knocks, busy means he is good, but I just can't see getting on the one year waiting list. I was real excited about the Kit Carlson fuel injection, but that seems to have faded away - again! So, now that my damn car is finally getting painted and I got my absolutely perfectly restored main wiring harness (yeah the whole damn thing down to the fuse panel, switches, you name it) restored by good ole Bowlsby and all the harnesses (fuel injection, alternator, etc) that Bowlsby makes - I said to hell with it I will just go back with the D-Jet, so it seems like a close to stock rebuild it will be. Then I still got to find someone to work on the 2.0 heads. Anyhow, for 100 hp how does this make sense? How come everybody likes these cars but nobody (at least nobody close by this frigid berg we call Massachusetts) wants to work on them? Raby, I wish to hell I was in GA, I'd drop the motor off on your door step and come get it in December? God, the 4 degrees outside is getting to me. At least we got the Patriots! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Jake Raby |
Jan 18 2005, 06:16 PM
William,
The Kit Carlson system has not faded away. The designer has been very busy with all the details. Making a quality product or kit takes time. He also is an engineer and not a businessman so he had alot of things to do to set up his business and book work- etc... I talk to him weekly as I continue to test his system and he never talks about not selling the system. I sometimes think its hard for guys to understand just how complex things are when trying to satisfy the buying public these days. As for my engines: For the first time EVER I have been able to pinpoint a scheduled engine build down to the week it will be finished. Currently the backlog is 33 engines and that puts us into the 3rd week of September for a delivery date. Its not a full year, although it has been before. I chose long ago to limit the number of engines we build and provide more quality through more man hours spent on the design and assembly and even the testing of the engine. It takes 80 man hours between Brent and I to create on of our standard engines and up to 120 for a SuperHero. I have no conmcern with doing a huge amount of engines. In 1997 we did 70 engines, last year we only did 40. The 40 of last year were WAY more developed than the 70 in 1997. Every year I want to keep dropping our volume and upping the quality and development. Hell I will be happy the day that I can build 10 engines per year and make them absolute bad ass... All while supplying the rest of the world with the best parts and designs available for the to do their own work. The services I offer are unavailable anywhere else. The combos I have designed and the testing put into them is unparalleled. No one else has the coating technology, valve train parts, head specs and overall performance combinations that I do... Thats because they are concerned with volume numbers and keeping 20 employees paid..... Here its just Brent and I.... Just wait till February and you'll be able to have a "Raby inspired" engine easier than ever before.... Just without our assembly! |
TheCabinetmaker |
Jan 18 2005, 06:44 PM
You can sign me up for a set, and a set of 96mm KB pistons and suitable ring set too. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Rocky |
Jan 18 2005, 06:49 PM
From the cockpit Group: Members Posts: 341 Joined: 24-March 04 From: Gig Harbor,WA Member No.: 1,845 |
Jake, I like the fact they are stock configuration lighter and stronger. Us Gig Harbor boyz like speed. (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) Count me in for a set. (IMG:http://www.914world.com/bbs2/html/emoticons/rocking nana.gif)
Tim |
Lo-Fi Version | Time is now: 28th April 2024 - 11:33 PM |
