WATERBOXER |
WATERBOXER |
Type 4 Unleashed |
Jan 17 2005, 10:13 PM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
Says, it's a 2474, 205 HP at the wheels, Alt is a Suzuki GSXR 1100, hidden radiator. This is different. Made in Germany.
Richard Attached image(s) |
Type 4 Unleashed |
Jan 17 2005, 10:14 PM
PIC 2
DJsRepS |
Jan 18 2005, 06:15 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
The block looks simular to our 914's, the tranny hook up and the dist same place. What motor is this water cooled beast? VW/Por Boxter/not.
Walter |
Jan 18 2005, 06:52 AM
Member Group: Members Posts: 70 Joined: 10-August 04 From: The Netherlands, Europe Member No.: 2,499 |
Vanagon based. T3 Buses. Originally 2,1 ltr (94x76,4) and the best ones had 112 hp in Europe. Oettinger made 98x82 versions which had about 140 hp IIRC. 204 hp seems extremly high in that respect. Regards, Walter |
DJsRepS |
Jan 19 2005, 06:35 AM
Will it bolt into a 914?
Mueller |
Jan 19 2005, 09:41 AM
look at the exhuast...that would be the most difficult part in my opinion...the rest should be pretty easy, just new brackets and such...and of course the radiator... i'd put in a subaru motor before I installed a vanagon engine in my car |
Root_Werks |
Jan 19 2005, 10:16 AM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I read an artical not that long ago about someone putting a bus waterboxer in a type1. Wasn't 200hp, but very nicely done. Just the way the type1 is set up, you would think it money ahead to put in a 180hp air cooled engine from Scat or something? Seems like the plumbing would "hack" the little bug up?
I put a 914 1.7 into a 66' bug when I was in high school. It was the quickest bug around back then. (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
davesprinkle |
Jan 19 2005, 10:28 AM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
The waterboxer engines ran the head studs through the water jacket. A typical failure mode was for the studs to rust and subsequently break. VW specified a special antifreeze to prevent this failure, but many owners didn't use it and so a lot of these engines suffer from compression leaks, oil leaks, water leaks, etc. -- all the symptoms you might expect from a broken head stud. Just something to consider, should you be tempted by a cheap, high-mileage waterboxer...
Rhodes71/914 |
Jan 19 2005, 11:15 AM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
This is exactly why the Vanagons with those engines do the Subaru swap. I was looking at a late 80's Vanagon a couple of years ago and when i was figuring maintenance costs I included the cost of putting doing the subby swap. Cause I knew the waterboxer would go at some point. Didn't buy it though, guy thought it was worth to much. Sean |
bernbomb914 |
Jan 19 2005, 11:51 AM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
will a waterboxer 76.4 crankshaft fit a type 4 case?. and are they strong enough if they fit?
Bernie |
Walter |
Jan 19 2005, 12:11 PM
The waterboxer 76,4mm cranks are the strongest cranks ever made. They will fit a type 1, but not a type 4. They do have the same 5 bolt flywheel connection like the type 4 tho. Type 4 flywheels will fit therefore (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) On the other hand, stock the wbx's have a very nice 228mm forged flywheel. Very nice engines, especially the case is a beauty. All alu like the type 4 with spun on filter and about 5 liter sump as standard (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) Regards, Walter |
Type 4 |
Jan 19 2005, 12:13 PM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
The crank wont fit a Type 4 But they go right in a Type 1 case.
I use the WBX crank and 90.5 pistons for my type 1 bus engines. |
Type 4 |
Jan 19 2005, 12:18 PM
balthazar |
Jan 19 2005, 01:07 PM
P-car junkie Group: Members Posts: 161 Joined: 23-March 03 From: Arvada, Colorado Member No.: 464 |
I tend to agree with the conclusion that a WBX engine is just a failure waiting to happen, although my experience is different. They start to get coolant into the combustion chamber, and then it's all over. The Sooby is the conversion of choice, and consequently, the cheapest route.
When I bought my Kombi in 1996, it had 85k on it and thankfully, the PO had kept it in immaculate condition. I have reciepts all the way back to 86' to include the original window sticker! Since then I have put a zillion miles on it and it still pulls strong. I routinely drove it from state to state on business. By far the most reliable vehicle I have ever owned. I guess the point is if you take good care of them, and follow up on maintainance, they can be a reliable engine. The problem here is that people don't read the manual, and there is no telling what the PO did with the vehicle. This gives the design an unfair reputation. I too was planning on doing the sooby convert when the engine blew out, but I have not had the chance as she will not die! All hail the super WBX! (IMG:http://www.914world.com/bbs2/html/emoticons/tongue.gif) |
balthazar |
Jan 19 2005, 01:18 PM
1986 VW Kombi Wasserboxer
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 06:00 PM |
