both doors wont open, how do you open a door |
rmdinmd |
Jun 14 2014, 10:20 AM
Member Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States |
(IMG:style_emoticons/default/WTF.gif) everything was working fine 3 weeks ago. went to open the doors and niether one will open, they are not locked. I have already previously replaced the cam mech, cleaned and lubed them and everything was working fine, door gap seems ok. no clue what happened. (IMG:style_emoticons/default/confused24.gif)
Any suggestions on how to get door open with out doing damage? TIA Rick |
Steve |
Jun 14 2014, 10:27 AM
914 Guru Group: Members Posts: 5,614 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
long coat hanger from the opposite side. Never heard of this problem before. Usually its when you lock your keys in the car.
Dr Evil |
Jun 14 2014, 10:51 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Is it sagging?
jmill |
Jun 14 2014, 11:34 AM
Is it sagging? That would suck. You can check though. Put a jack under the body just forward of the rear of the door. Jack the car up a bit to relieve stress and door should open. Then close door before your car folds in half. Attached image(s) |
bandjoey |
Jun 14 2014, 11:59 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Since they are not locked an it's both doors it sure sounds like a sagging body. Call Scotty for repairs. Good luck. (IMG:style_emoticons/default/sad.gif)
rmdinmd |
Jun 14 2014, 02:43 PM
ok, got the doors open. (IMG:style_emoticons/default/piratenanner.gif) Persistance paid off along with some hard jiggles. (IMG:style_emoticons/default/biggrin.gif)
It isn't sagging , (saw that thread doing a search (IMG:style_emoticons/default/sad.gif) , glad it didn't apply ) but the latch doesn't want to release. It doestn't release freely working it with the door open. I am just going to leave the window open for now. will have to take it back apart and might see about replacing the spring. I had already cleaned both sides with a toothbrush and break cleaner and then ran the passenger side through an ultra sonic cleaner for about a half an hour or better so you would think it would be clean. I just have a project to work on to figure this out. |
Harpo |
Jun 14 2014, 03:00 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Glad to hear that the problem is not sagging. That would be an expensive repair.
David (IMG:style_emoticons/default/evilgrin.gif) |
mrholland2 |
Jun 14 2014, 09:23 PM
Senior Member Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
ok, got the doors open. (IMG:style_emoticons/default/piratenanner.gif) Persistance paid off along with some hard jiggles. (IMG:style_emoticons/default/biggrin.gif) It isn't sagging , (saw that thread doing a search (IMG:style_emoticons/default/sad.gif) , glad it didn't apply ) but the latch doesn't want to release. It doestn't release freely working it with the door open. I am just going to leave the window open for now. will have to take it back apart and might see about replacing the spring. I had already cleaned both sides with a toothbrush and break cleaner and then ran the passenger side through an ultra sonic cleaner for about a half an hour or better so you would think it would be clean. I just have a project to work on to figure this out. Mine did this, if I pushed in on the door slightly as I pulled the latch, they opened. . much lubrication and some minor adjustments corrected the problem |
Valy |
Jun 15 2014, 10:51 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
ok, got the doors open. (IMG:style_emoticons/default/piratenanner.gif) Persistance paid off along with some hard jiggles. (IMG:style_emoticons/default/biggrin.gif) It isn't sagging , (saw that thread doing a search (IMG:style_emoticons/default/sad.gif) , glad it didn't apply ) but the latch doesn't want to release. It doestn't release freely working it with the door open. I am just going to leave the window open for now. will have to take it back apart and might see about replacing the spring. I had already cleaned both sides with a toothbrush and break cleaner and then ran the passenger side through an ultra sonic cleaner for about a half an hour or better so you would think it would be clean. I just have a project to work on to figure this out. Been there with the ultrasonic cleaner . they don't like it much and tend to get stuck after a while. You need to grease them good and maybe replate to prevent corrosion . I noticed that in my case the door lock was not completely closed so pushing the door close helped release the mechanism and then the door could be opened normally from the external handle. |
rmdinmd |
Jun 22 2014, 12:37 PM
Ok;
I found a gallon jug of penetrating oil and soaked the lock mechinisms in it for several hours working them at times. That seems to have done the trick as both handles open the doors easier then ever and I can lock and unlock the doors easy also. So hopefully that will solve the problem as they should be well lubed and the oil even extracted some more dirt. time will tell but I will leave a window open until I am sure. So lesson learned, make sure you have it WELL LUBED and just spraying it won't do it. |
Lo-Fi Version | Time is now: 11th June 2024 - 09:21 PM |
