Stock oil baffle, Mod?? |
Jetsetsurfshop |
Jun 15 2014, 08:48 AM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Hey Paddock people,
Any thoughts in enlarging the drain back hole? I also have a questions in the oil filler neck. I used PST 565 (loctite) for the o-ring seal. Its been leaking. Maybe not liberal enough with the goo? Shane HAPPY DAD DAY, EVERYONE!!!! (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
McMark |
Jun 24 2014, 12:54 AM
There are other versions of that piece with a larger hole. The ones with the PCV valve. You can gut the PCV valve to increase flow, or you could weld a section of pipe on in place of the PCV. But in a stock setup, that's not a drain back, it's just a path for air to flow (with some oil vapor).
Woody |
Jun 25 2014, 06:11 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
There are other versions of that piece with a larger hole. The ones with the PCV valve. You can gut the PCV valve to increase flow, or you could weld a section of pipe on in place of the PCV. But in a stock setup, that's not a drain back, it's just a path for air to flow (with some oil vapor). I just drilled straight through mine with a 3/4" drill bit. (IMG:style_emoticons/default/sawzall-smiley.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:28 PM |
