Who uses this ?, Saw it at the Parade |
jim_hoyland |
Jun 15 2014, 08:28 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Special oil ? Anyone have an opinion on this:
carr914 |
Jun 16 2014, 04:42 AM
Racer from Birth Group: Members Posts: 118,917 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
probably $15 a Quart!
Can looks cool though |
JRust |
Jun 16 2014, 07:47 AM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
10w60 is a new one for me. Never seen that weight before (IMG:style_emoticons/default/confused24.gif)
Johny Blackstain |
Jun 16 2014, 07:52 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
Again I have to ask, how can they justify this when there is a boatload of 911s out there w/ this sticker in the engine compartment?
Qarl |
Jun 16 2014, 10:40 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Again I have to ask, how can they justify this when there is a boatload of 911s out there w/ this sticker in the engine compartment? It's designed for the older engines with older alloys, different seals and seal materials, and less precise tolerances. I think that is the reason, from what I read in the Original post. LOL Newer synthetics probably work better in the newer technology engines. |
worn |
Jun 16 2014, 11:34 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
10w60 is a new one for me. Never seen that weight before (IMG:style_emoticons/default/confused24.gif) I understood that 10-40 was beyond realistic expectations already. Covering 10/60 is quite something. |
PotterPorsche |
Jun 16 2014, 11:45 AM
Member Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None |
I like using Brad Penn 20-50 on older engines, or engines I know no history of. I use 10-30 on new engines with tighter tolerances
KELTY360 |
Jun 16 2014, 01:14 PM
914 Neferati Group: Members Posts: 5,034 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Don't be silly...it was obviously designed for Real Porsches. (IMG:style_emoticons/default/dry.gif)
Reno914 |
Jun 16 2014, 04:33 PM
Newbie Group: Members Posts: 31 Joined: 18-August 09 From: Reno Member No.: 10,694 Region Association: Northern California |
Found it here, but currently is on Back-Order.
http://www.suncoastparts.com/product/SKU20...=newproductpage price is $13.65 per Reno |
seareef228 |
Jun 16 2014, 04:37 PM
Newbie Group: Members Posts: 32 Joined: 13-May 14 From: so cal Member No.: 17,347 Region Association: None |
Found it here, but currently is on Back-Order. http://www.suncoastparts.com/product/SKU20...=newproductpage price is $13.65 per Reno Alanta has it for 10 bucks a qt |
monkeyboy |
Jun 17 2014, 09:05 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Ten bucks a quart isn't bad if it's a high zinc oil designed for our engines.
Justinp71 |
Jun 17 2014, 10:45 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I've been hearing really good things about Delo 400, Henry Schmidt that runs Supertec uses it exclusively- http://forums.pelicanparts.com/911-engine-...-detergent.html
skier2.0 |
Jun 17 2014, 10:57 AM
Newbie Group: Members Posts: 34 Joined: 30-May 14 From: United States Member No.: 17,422 Region Association: MidAtlantic Region |
Tolerances - check them basically no differences-check the spec books, mains,rods,end play,ring gaps etc,etc all the same. Old wives tale just BS based on no facts.
BMW has been using 10-60 on some of their M motors for years. Flat tappet engines 356,914,912e like extra ZDDP to prolong cam and lifter life. 6 Cyl engines don't need the extra ZDDP and any with a Cat converter should use an oil with lower ZDDP count. Just contact any oil co's tech line for the real information. |
carr914 |
Jun 17 2014, 01:14 PM
probably $15 a Quart! Can looks cool though Found it here, but currently is on Back-Order. http://www.suncoastparts.com/product/SKU20...=newproductpage price is $13.65 per Reno I wasn't far off! |
monkeyboy |
Jun 17 2014, 03:46 PM
I've been hearing really good things about Delo 400, Henry Schmidt that runs Supertec uses it exclusively- http://forums.pelicanparts.com/911-engine-...-detergent.html Delo might work well in a 6, but I would not run it in a 4. Flat tappet cams need more zinc and phosphorus. Delo has little of that anymore. They cut back on the diesel engine oils a couple of years ago. |
AZ914 |
Jun 17 2014, 03:47 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
I'd buy a quart just for the can, then fill it with my usual stuff, keep it in the frunk.
jim_hoyland |
Jun 17 2014, 04:45 PM
Justinp71 |
Jun 17 2014, 04:46 PM
I've been hearing really good things about Delo 400, Henry Schmidt that runs Supertec uses it exclusively- http://forums.pelicanparts.com/911-engine-...-detergent.html Delo might work well in a 6, but I would not run it in a 4. Flat tappet cams need more zinc and phosphorus. Delo has little of that anymore. They cut back on the diesel engine oils a couple of years ago. It had the highest zinc and phosphorus in this test done last year- http://www.pqiamerica.com/March2013PCMO/HD...UMMARYrev2.html |
914_teener |
Jun 17 2014, 05:42 PM
914 Guru Group: Members Posts: 5,204 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
No teener on the can.....
Not in my car. |
Jake Raby |
Jun 18 2014, 12:58 AM
We'll soon know exactly what the composition of this oil is. More than likely we already know who is making the additive package, its just a matter of confirming some suspicions.
Its a great thing that Porsche did releasing this oil. Between the release and the text on their site describing the oil a vehicle manufacturer has finally admitted that modern oils are not optimum for vintage engines. Thanks guys, you proved what we've been trying to tell people since 2001. I expect the 10/60 to have an incredible amount of shear. We shall see. |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:06 PM |
