12pt male socket for oil relief on side of case, Where to buy 12pt socket |
lonewolfe |
Jun 21 2014, 01:40 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
I have been trying to find the 12 pt male socket that is used to remove the oil relief nut from the side of the engine case. I believe it is 13mm or 14mm. I thought Sears might have it but no luck. None of the local auto parts stores have it either.
Any suggestions? |
jacksun |
Jun 21 2014, 02:07 PM
Member Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
stugray |
Jun 21 2014, 02:09 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I think that is the one that Mcmark (or someone else on this forum) said that a 3/8" extension fits in there.
914Sixer |
Jun 21 2014, 02:52 PM
914 Guru Group: Members Posts: 8,907 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have a Stahwille one if you would like to borrow it.
budk |
Jun 21 2014, 03:16 PM
Yes! It's a Bumblebee! Group: Members Posts: 679 Joined: 24-July 10 From: Hickory, PA Member No.: 11,970 Region Association: MidAtlantic Region |
NAPA, or most other Auto parts stores.
ChrisFoley |
Jun 21 2014, 03:49 PM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
barefoot |
Jun 22 2014, 08:21 AM
Senior Member Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I think that is the one that Mcmark (or someone else on this forum) said that a 3/8" extension fits in there. Yep, 3/8 extension works just fine, thanks for the tip. Slight hijack however; I have 2 motors partially dis-assembled, a 2L that has this relief valve and an older motor of 1.7 or 1.8 vintage --W1 & GC003110 markings (was in my 76 when i got it) that has this hole plugged with a deep pressed in plug, were older motors configured differently, or did some PO do some unapproved mods ??? That car had an external oil cooler mounted using a thermostatically controlled device sandwiched over the oil filter. Barefoot |
barefoot |
Jun 23 2014, 06:45 AM
Bump (IMG:style_emoticons/default/icon_bump.gif)
krazykonrad |
Jun 23 2014, 12:42 PM
Senior Member Group: Members Posts: 1,128 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
I got mine from Summit Racing as well.
Konrad |
Valy |
Jun 23 2014, 02:31 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Not all engines had the 2nd relief valve.
I have a single relief case. |
JFJ914 |
Jun 23 2014, 04:20 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
I think that is the one that Mcmark (or someone else on this forum) said that a 3/8" extension fits in there. Yep, 3/8 extension works just fine, thanks for the tip. Slight hijack however; I have 2 motors partially dis-assembled, a 2L that has this relief valve and an older motor of 1.7 or 1.8 vintage --W1 & GC003110 markings (was in my 76 when i got it) that has this hole plugged with a deep pressed in plug, were older motors configured differently, or did some PO do some unapproved mods ??? That car had an external oil cooler mounted using a thermostatically controlled device sandwiched over the oil filter. Barefoot GC engines were single relief. No unapproved mod. |
Lo-Fi Version | Time is now: 12th June 2024 - 09:11 AM |
