Headlight carrier, which 1 is correct for a 74 2.0 |
seareef228 |
Jun 22 2014, 09:00 AM
Newbie Group: Members Posts: 32 Joined: 13-May 14 From: so cal Member No.: 17,347 Region Association: None |
ok guys I pulled both these off my car I am assuming the pass side is incorrect but I am not positive if you look closely they are different years also pass side has a black trim ring and the driver side has a chrome trim ring. They are positioned exactly like I removed them . driver on the left, pass on right
which one is correct for a 1974 2.0 |
malcolm2 |
Jun 22 2014, 09:34 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
i have one of each.... i always figured the only difference was the 2 little holes on the "U" that grabs the bolt as they open. I assumed the one with 2 little holes was a late style... not sure when "late" started, maybe 74. Mine work fine on my 75. They are "handed" tho. You need a Righty and a Lefty. you appear to have one of each (side).
Check around the front looking for evidence of an accident. If it has been wrecked and fixed, they may have gotten on older style part since they might have been cheaper than a brand new one. Clark |
seareef228 |
Jun 22 2014, 10:01 AM
i have one of each.... i always figured the only difference was the 2 little holes on the "U" that grabs the bolt as they open. I assumed the one with 2 little holes was a late style... not sure when "late" started, maybe 74. Mine work fine on my 75. They are "handed" tho. You need a Righty and a Lefty. you appear to have one of each (side). Check around the front looking for evidence of an accident. If it has been wrecked and fixed, they may have gotten on older style part since they might have been cheaper than a brand new one. Clark that's exactly what happened its super minor (more like a tap and the bodyman did a great job ,,I am a body man /painter am I am satisfied it appears the headlight did get replaced with the wrong carrier, the one with the u and the 2 little holes was on the pass side I am thinking this and the black trim are wrong ??? I just want 2 the same and the correct part for my year ,.. |
69telecaster |
Jun 23 2014, 05:40 AM
Member Group: Members Posts: 101 Joined: 4-April 10 From: White Cloud, MI Member No.: 11,558 Region Association: None |
My '73 does not have the little holes, but the '74 and a '76 do have them. I could check a '70, a '72, and another '76 later today, if more evidence is needed.
cm |
bdstone914 |
Jun 23 2014, 07:36 AM
bdstone914 Group: Members Posts: 4,538 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The carriers are functionally interchangeable. Chrome ring were on early cars and painted on later. You can just swap the ring to make them look the same. The difference in the tab does show if you look through the gap when the lights are closed. I probably have extras of you want to swap the whole carrier or just the ring.
Bruce |
seareef228 |
Jun 23 2014, 08:20 AM
The carriers are functionally interchangeable. Chrome ring were on early cars and painted on later. You can just swap the ring to make them look the same. The difference in the tab does show if you look through the gap when the lights are closed. I probably have extras of you want to swap the whole carrier or just the ring. Bruce that would be Awesome I am going to PM you Thanks you Bruce |
Lo-Fi Version | Time is now: 11th June 2024 - 01:26 PM |
