Pedal Board install?, tricks to try |
malcolm2 |
Jun 22 2014, 09:21 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I have pretty much tried every angle and it just will not go. I have now determined that I must remove the accel pedal.... CORRECT?
Clark |
cary |
Jun 22 2014, 09:32 AM
Pedal no. Just pop the rod off the pedal. Hold the rod with one hand. Then pull the pedal backwards.
Then IIRC start with the accelerator side. Slide over brake, then clutch. |
TheCabinetmaker |
Jun 22 2014, 09:36 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
No. Just pull the top of the gas pedal and pop it off the ball on the linkage. Put the clutch through the hole then the brake. You have to turn the board sideways a bit to get the pedal in the hole. The reinstall gas pedal, spit in the hole in the back of the pedal, place it on the linkage ball, and slap the pedal sharply with the heel of your hand.
malcolm2 |
Jun 22 2014, 09:43 AM
Thanks guys.... At least I was 1/2 right. Cable disconnect only should be easier.
Clark |
TheCabinetmaker |
Jun 22 2014, 09:51 AM
How about that for service? Question answered in ten minutes. I've gone days or weeks getting a q answered at the vette forums.
malcolm2 |
Jun 22 2014, 02:10 PM
1. Just pull the top of the gas pedal and pop it off the ball on the linkage. 2. Put the clutch through the hole then the brake. 3. You have to turn the board sideways a bit to get the pedal in the hole. 4. Then reinstall gas pedal, 5. spit in the hole in the back of the pedal, place it on the linkage ball, and slap the pedal sharply with the heel of your hand. As a follow up.... I did not do number 5. #4 was the toughest part cause when you push down on the pedal.... it now hits the board vs. bottoming out. So it takes both hands on the pedal and the linkage to re-seat it. I will also add for future searches that if you remove the clutch and brake foot pads it is much easier. I am curious about the wire routing now. I have not re-attached the cover plate at that end of the tunnel yet. But the board seems to be resting on the wires. And what is the hole to the right of the accel pedal for? Am I using an incorrect board for my 75? Clark |
hndyhrr |
Jun 22 2014, 03:16 PM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
And what is the hole to the right of the accel pedal for? Am I using an incorrect board for my 75? hole on right side bottom is for screw and plate that screws into the cover plate for hole into tunnel. wires should go under and thru not over, then foot board will not rest on them. hang on let me get a pic for you, as my foot board is out for pedal cluster rebuild |
hndyhrr |
Jun 22 2014, 03:17 PM
pic is poor quality but that is how it goes together |
02loftsmoor |
Jun 22 2014, 03:31 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
move that Red wire
Jun 22 2014, 07:05 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You're missing the cover that goes over the square hole in the center tunnel. that cover has a bracket with a threaded hole to mount your pedal board to.
(IMG:style_emoticons/default/smile.gif) |
Jun 22 2014, 09:25 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
MDG |
Jun 23 2014, 07:12 AM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
This is the go to thread for all things pedal board.
(IMG:style_emoticons/default/thumb3d.gif) http://www.914world.com/bbs2/index.php?showtopic=190018 |
PANTLODE |
Jun 23 2014, 07:13 AM
Hold still.... Group: Members Posts: 96 Joined: 1-December 11 From: Cottonwood Heights, UT Member No.: 13,840 Region Association: None |
This is the go to thread for all things pedal board. (IMG:style_emoticons/default/thumb3d.gif) http://www.914world.com/bbs2/index.php?showtopic=190018 (IMG:style_emoticons/default/dry.gif) |
malcolm2 |
Jun 23 2014, 09:25 AM
This is the go to thread for all things pedal board. (IMG:style_emoticons/default/thumb3d.gif) http://www.914world.com/bbs2/index.php?showtopic=190018 There is a reason that I did not find that post when searching..... someone should move it to the sandbox. (IMG:style_emoticons/default/lol-2.gif) And lets make this the go to for pedal board installs. (IMG:style_emoticons/default/smash.gif) |
malcolm2 |
Jun 23 2014, 09:28 AM
You're missing the cover that goes over the square hole in the center tunnel. that cover has a bracket with a threaded hole to mount your pedal board to. (IMG:style_emoticons/default/smile.gif) I have the cover. But did not know a "button" screwed to it. I'll dig up the cover today and see what I can make. No carpet yet either, so there is no rush. The wires were that way when I got the car. I did not move them out of the hole, and I am now not going to move them..... way too much work and opportunity for a major screw up. I can't imagine that my PO did it either. |
AvalonFal |
Jun 23 2014, 10:33 AM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
malcolm2 |
Jun 24 2014, 07:39 AM
That helps in a few ways. I am now installing B-Quiet Ultimate mat. I see you have something similar. I was planning to add some carpet padding of some sort. Your does not have any. A Ford guy here at work is trying to get me a local source for JUTE (sp?) which might be what Porsche used. And I can just about see the hold down screw on the right of the accel pedal. Still need to search for my cover. But I did order carpet. I got the cheaper loop version from 914 rubber. Anyone have any comments on that style vs. perlon or their better loop? |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:03 PM |
