QUOTE(The Cabinetmaker @ Jun 22 2014, 10:36 AM)
1. Just pull the top of the gas pedal and pop it off the ball on the linkage.
2. Put the clutch through the hole then the brake.
3. You have to turn the board sideways a bit to get the pedal in the hole.
4. Then reinstall gas pedal,
5. spit in the hole in the back of the pedal, place it on the linkage ball, and slap the pedal sharply with the heel of your hand.
As a follow up.... I did not do number 5. #4 was the toughest part cause when you push down on the pedal.... it now hits the board vs. bottoming out. So it takes both hands on the pedal and the linkage to re-seat it.
I will also add for future searches that if you remove the clutch and brake foot pads it is much easier.
I am curious about the wire routing now. I have not re-attached the cover plate at that end of the tunnel yet. But the board seems to be resting on the wires.
And what is the hole to the right of the accel pedal for? Am I using an incorrect board for my 75?
Clark
Click to view attachmentClick to view attachment
