who carries barrels and pins for connectors?, Found my dme relay problem! |
buck toenges |
Jun 22 2014, 02:49 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
I have had a problem with dme relays over the last few years with my 3.2. Once it was a reference sensor, once is was a speed sensor, once it was the bolt on the flywheel for the reference sensor. But lately I have had to replace the dme relay.
I got the car out finally but I would get the car to start and when I turned it off then it wouldn't start again. So I changed the dme relay and it would start but the same thing would happen. So I am saying sh*t what is going on now. But before I pulled out the bentley book I decide to look at the dme connector to the harness. I found one barrel only connected by a thin wire. I soldered the barrel back to the wire and the dme worked. Over and over again the dme worked. I would like to get some new barrels and pins so I can do a better job of soldering them up. The current one is kinda banged up. Who carries them? Thanks, Buck |
JeffBowlsby |
Jun 22 2014, 09:21 PM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Jun 22 2014, 09:41 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Wurth probably does.
--DD |
69telecaster |
Jun 23 2014, 05:46 AM
Member Group: Members Posts: 101 Joined: 4-April 10 From: White Cloud, MI Member No.: 11,558 Region Association: None |
First place I look for stuff like that is Newark Electronics...
cm |
Lo-Fi Version | Time is now: 11th June 2024 - 08:44 PM |
