I have had a problem with dme relays over the last few years with my 3.2. Once it was a reference sensor, once is was a speed sensor, once it was the bolt on the flywheel for the reference sensor. But lately I have had to replace the dme relay.
I got the car out finally but I would get the car to start and when I turned it off then it wouldn't start again. So I changed the dme relay and it would start but the same thing would happen. So I am saying sh*t what is going on now. But before I pulled out the bentley book I decide to look at the dme connector to the harness. I found one barrel only connected by a thin wire. I soldered the barrel back to the wire and the dme worked. Over and over again the dme worked.
I would like to get some new barrels and pins so I can do a better job of soldering them up. The current one is kinda banged up. Who carries them?
Thanks,
Buck
