914 racer, 914 scca runoffs |
fp racer |
Jun 23 2014, 10:02 PM
Newbie Group: Members Posts: 15 Joined: 25-December 09 From: san jose ca. Member No.: 11,172 Region Association: None |
I am qualified for the scca runoffs at laguna. This video was a race this year. I need to find 4 seconds a lap if I want to run up front. I still need to work out the jetting on my Solex carbs
http://youtu.be/JxBHjtvolko |
puffinator |
Jun 24 2014, 05:52 AM
Member Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
I am qualified for the scca runoffs at laguna. This video was a race this year. I need to find 4 seconds a lap if I want to run up front. I still need to work out the jetting on my Solex carbs http://youtu.be/JxBHjtvolko Awesome video. good luck |
ww914 |
Jun 24 2014, 07:27 AM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
I am qualified for the scca runoffs at laguna. This video was a race this year. I need to find 4 seconds a lap if I want to run up front. I still need to work out the jetting on my Solex carbs http://youtu.be/JxBHjtvolko Sounds pretty strong going up the hill. Hang in there. |
ThePaintedMan |
Jun 24 2014, 09:34 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
You are Albert, correct?
Sounds good man. You're definitely giving them hell. I saw a couple areas where it looks like you're turning in early then stabbing the gas to get the car to turn. I bet a few more laps under your belt would help with confidence turning in later and holding momentum through the turns, but you probably already know that stuff. What's going on with the Solexes? |
Randal |
Jun 24 2014, 10:04 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Which Solexes are your running? Greg McNair might be a good guy to call. He heading to the Cascade Lakes Hill Climb this week, but will be back next. |
fp racer |
Jun 24 2014, 01:21 PM
The carbs are P40s. In that video they were running really rich off the bottom. We tried different jets. Every time we change the main jet we have to change air corrector jet. My racing line is different because I am driving around the carb problem. |
jmill |
Jun 29 2014, 03:14 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Excellent vid. Thanks for sharing.
I'm a Weber guy but the Solex design has emulsion tubes and A/C jets similar to the Weber. Are emulsion tubes available that will give you low velocity mixture weakening (similar to the Weber F11)? You'd still have to change the A/C jet to adjust the high velocity mixture. |
Seabird |
Jul 7 2014, 02:20 PM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
Have you done anything to the stock shift linkage? Besides freshen up the bushings? I know from my own car missing a shift or struggling to find third throws me off my rhythm. Looks like you are having difficulties there too.
It wont amount to 4 secs a lap but it will certainly get you smoother and more confident. Miguel |
Heater Guy |
Jul 8 2014, 11:36 AM
Member Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California |
Al,
Where have you been? Haven't seen you at the SCCA races. Will you make the next one in Sept.? Give me a call. |
fp racer |
Jul 15 2014, 05:17 PM
Al, Where have you been? Haven't seen you at the SCCA races. Will you make the next one in Sept.? Give me a call. I haven't been to the regional races because I was racing the nationals. I'm all quailed now. I should be at the September race. How is your car running ? You get that trans all patched up? |
Lo-Fi Version | Time is now: 19th May 2024 - 07:45 AM |
