Windshield removal |
Sherlock |
Jun 24 2014, 07:58 PM
Newbie Group: Members Posts: 7 Joined: 15-January 14 From: North Carolina Member No.: 16,891 Region Association: South East States |
Anyone have a favorite tool for removing the trim around the windshield, and then the actual windshield? It's not the original windshield.
Sfreeman615 |
Jun 24 2014, 08:02 PM
Member Group: Members Posts: 146 Joined: 23-February 14 From: Nashville,TN Member No.: 17,033 Region Association: South East States |
Anyone have a favorite tool for removing the trim around the windshield, and then the actual windshield? It's not the original windshield. ice pick and a guitar string works the best to get the windshield out! I just used a small screw driver to get the trim off, but I wasn't worried about messing mine up, I'm going with the thick black rubber that they will install with the new windshield. |
bdstone914 |
Jun 24 2014, 10:20 PM
Use a sturdy box cutter knife along the edge of the trim and windshield frame. When you come to a clip tap the knife with a wood block or small hammer to cut through to clip. You can remove the trim all together without damage.
I then use the knife to cut through the butyl from the inside and outside. Then I use an old accelerator cable or other small stranded cable to saw through the butyl on the sides and top. From that point you can often push gently on the top and the bottom will break loose. Doing it on a hot day in the sun helps. |
dangrouche |
Jun 24 2014, 11:00 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
Lo-Fi Version | Time is now: 18th May 2024 - 02:49 AM |
