Scat vs Stock/OEM Crankshaft |
gla914#27 |
Jun 26 2014, 02:00 PM
Newbie Group: Members Posts: 7 Joined: 24-June 14 From: Michigan Member No.: 17,536 Region Association: None |
Am rebuilding my 2.0 race engine after a major failure
The existing crank is a Scat......stock stroke......which cannot be reused due to un-repairable damage to the flywheel end Am wondering if I should go again with the Scat with stock stroke or use one of my spare OEM stock crankshaft??????? |
URY914 |
Jun 26 2014, 02:13 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,662 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
So what is the difference in the two? (IMG:style_emoticons/default/confused24.gif)
gla914#27 |
Jun 26 2014, 02:33 PM
Scat is a forged.....light weight.....crankshaft |
Mark Henry |
Jun 26 2014, 02:45 PM
Scat is a forged.....light weight.....crankshaft Scat is forged in china, they hit it with a hammer a couple of times and call it forged. OE cranks are hammered many times right to the rough shape, they are a way higher quality forging. |
gla914#27 |
Jun 26 2014, 03:06 PM
You're the first I have heard to be negative about Scat Scat is a forged.....light weight.....crankshaft Scat is forged in china, they hit it with a hammer a couple of times and call it forged. OE cranks are hammered many times right to the rough shape, they are a way higher quality forging. |
Lo-Fi Version | Time is now: 18th May 2024 - 04:25 AM |
