| larryg |
Jun 26 2014, 02:39 PM
Newbie ![]() Group: Members Posts: 37 Joined: 5-February 14 From: portland oregon Member No.: 16,961 Region Association: None |
Everything in the instrument panel cluster works except the odometer which stopped turning a few years back. Suggestions on how to diagnose, or info on likely causes will be much appreciated.
| orthobiz |
Jun 26 2014, 03:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,762 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest
| larryg |
Jun 26 2014, 05:13 PM
| worn |
Jun 26 2014, 08:43 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,556 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
(IMG:style_emoticons/default/agree.gif) Done two, two worked. I used a punch to peen the flange and a bit of epoxy for luck. First one I did quite a while ago and still holding up. |
| stugray |
Jun 27 2014, 07:18 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE except the odometer which stopped turning a few years back This is a common problem with these cars. You have to take it down off the jackstands :-) |
Lo-Fi Version | Time is now: 10th March 2026 - 12:39 PM |
