Full Version: Odometer Problem
larryg
Everything in the instrument panel cluster works except the odometer which stopped turning a few years back. Suggestions on how to diagnose, or info on likely causes will be much appreciated.
orthobiz
Pelican odometer repair
Paul
larryg
QUOTE(orthobiz @ Jun 26 2014, 02:16 PM) *
Thanks Paul
worn
QUOTE(orthobiz @ Jun 26 2014, 01:16 PM) *
Done two, two worked. I used a punch to peen the flange and a bit of epoxy for luck. First one I did quite a while ago and still holding up.
stugray
This is a common problem with these cars.
You have to take it down off the jackstands :-)
