john77 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California ![]() ![]() |
Just drove an hour down to Irvine from LA to autocross. Pulled in to get gas just before I got to the track and now the damn car won't start. All I can hear is the fuel pump. Tried whacking the starter with a wrench, but no joy.
The only silver lining is that I paid the extra twenty bucks for the AAA upgrade so I can get towed up to 100 miles for free... |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,742 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Just drove an hour down to Irvine from LA to autocross. Pulled in to get gas just before I got to the track and now the damn car won't start. All I can hear is the fuel pump. Tried whacking the starter with a wrench, but no joy. The only silver lining is that I paid the extra twenty bucks for the AAA upgrade so I can get towed up to 100 miles for free... Push start it! Also, try sliding the spade fitting on/off the solenoid. They get dirty. Or jump the terminals on the starter. |
john77 |
Just drove an hour down to Irvine from LA to autocross. Pulled in to get gas just before I got to the track and now the damn car won't start. All I can hear is the fuel pump. Tried whacking the starter with a wrench, but no joy. The only silver lining is that I paid the extra twenty bucks for the AAA upgrade so I can get towed up to 100 miles for free... Push start it! Also, try sliding the spade fitting on/off the solenoid. They get dirty. Or jump the terminals on the starter. You sir, are a god among men!! Push started it and made tech with 1 min to spare (embarrassingly I really should have known to do that... Well, now I do.) |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Just drove an hour down to Irvine from LA to autocross. Pulled in to get gas just before I got to the track and now the damn car won't start. All I can hear is the fuel pump. Tried whacking the starter with a wrench, but no joy. The only silver lining is that I paid the extra twenty bucks for the AAA upgrade so I can get towed up to 100 miles for free... Push start it! Also, try sliding the spade fitting on/off the solenoid. They get dirty. Or jump the terminals on the starter. You sir, are a god among men!! Push started it and made tech with 1 min to spare (embarrassingly I really should have known to do that... Well, now I do.) A god among men? Naaah, he's from Texas! (IMG:style_emoticons/default/laugh.gif) |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Heat soak. After checking/refurbishing ALL the major grounds, ignition circuit, and battery connections, buy a Bosch new or remanufactured starter. Might wanna install a 6v Ford starter solenoid at the same time, using appropriately sized wire.
The Cap'n |
john77 |
Heat soak. After checking/refurbishing ALL the major grounds, ignition circuit, and battery connections, buy a Bosch new or remanufactured starter. Might wanna install a 6v Ford starter solenoid at the same time, using appropriately sized wire. The Cap'n Thanks Cap'n, I'll start working through this tomorrow. |
Lo-Fi Version | Time is now: 18th July 2025 - 11:06 PM |
