| JeffBowlsby |
Jul 1 2014, 07:08 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,231 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
1. For a 1975-76 California-market 914, a flashing EGR dash light means what?
a. The EGR valve has become too hot. b. The 30KMI service interval for the EGR system has been reached. c. The EGR dash light does not flash when it activates. d. The EGR system needs to be removed to keep this from happening again Answer: C. The EGR light is only a steady light at 30KMI intervals. The CAT light is also steady at 30KMI and flashes when it overheats. 2. How many different factory 914/4 oil temperature sender wires (green/black stripe) were available through all model years, excluding the chassis harness wiring? a. 1 b. 2 c. 3 d. 4 Answer: C. 1970-71, sender to ignition harness. 72=none. 1973-76, sender to chassis harness for center console gauge, and center console to dash area for non-center console cars. 3. The 914’s removable hardtops are identical across all model years. a. True b. False Answer: False. Early and late styles are different and not interchangeable Post more Questions/Answers that might make good Parade 914 tech quiz questions - Share your knowledge. |
| r_towle |
Jul 1 2014, 07:14 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
First question made me mad at you .
(IMG:style_emoticons/default/smile.gif) |
| JeffBowlsby |
Jul 2 2014, 10:39 AM
What...no one wants to play? Here is another:
1. To install H4 headlights into a USA 914, the original factory rubber sealing boot must be replaced also. a. True b. False Answer: True. The factory manual describes replacing the original black rubber boot with a red rubber boot and the transparent electrical connector housing with a polyamide (nylon) connector housing for better heat resistance. |
| Dave_Darling |
Jul 2 2014, 11:40 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I think most of these so far are a bit too fussy for Parade. (IMG:style_emoticons/default/smile.gif)
The top question is a good one, though. The wires question is unclear. I've already written up a couple of tech quizzes in the past, most of what comes to mind are questions from those. --DD |
| bandjoey |
Jul 2 2014, 06:59 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
The original Cabin Light has a chrome edge and is made in Mexico
True / False The original Cabin Light has a White unobtanium switch True / False |
| bdstone914 |
Jul 2 2014, 11:00 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,288 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What...no one wants to play? Here is another: 1. To install H4 headlights into a USA 914, the original factory rubber sealing boot must be replaced also. a. True b. False Answer: True. The factory manual describes replacing the original black rubber boot with a red rubber boot and the transparent electrical connector housing with a polyamide (nylon) connector housing for better heat resistance. What original rubber boot? Never seen one. |
| JeffBowlsby |
Jul 2 2014, 11:37 PM
This one...
| JeffBowlsby |
This one...
Attached thumbnail(s) |
| ClayPerrine |
Jul 3 2014, 07:42 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Here are two from some tech quizzes that I wrote in the past.
I will post the right answers tomorrow. ================================ You and a friend go to look at a 914 /6 you saw in the paper. It is advertised as an original six, but your friend says that it can’t be a real six because the key is in the right side of the column rather than in the dash on the left. You look under the dash, and you cannot see any evidence of wiring modifications. A. Your friend is right, it’s a conversion. B. It was a factory special order car. C. It is a real /6, made in 72 with a 4 cylinder column to cut costs. D. It is a real /6, with a 4 cylinder replacement column installed by a previous owner. 4. The 914/4 was made in eight different varieties. Which of them came from the factory with twin Solex carburetors? A. Eurospec 1.8L B. Very early 1.7L C. Eurospec 2.0L D. None, all 914 four cylinders came with fuel injection. |
| 76-914 |
Jul 3 2014, 07:46 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,878 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
How many cuss words does it require to install springs on a glove box door?
A - None B - 40-50 C - north of 400 D - All you know plus a few new ones |
| 914_teener |
Jul 3 2014, 08:46 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
| bandjoey |
Jul 3 2014, 09:58 AM
Here are two from some tech quizzes that I wrote in the past. I will post the right answers tomorrow. ================================ You and a friend go to look at a 914 /6 you saw in the paper. It is advertised as an original six, but your friend says that it can’t be a real six because the key is in the right side of the column rather than in the dash on the left. You look under the dash, and you cannot see any evidence of wiring modifications. A. Your friend is right, it’s a conversion. B. It was a factory special order car. C. It is a real /6, made in 72 with a 4 cylinder column to cut costs. D. It is a real /6, with a 4 cylinder replacement column installed by a previous owner. 4. The 914/4 was made in eight different varieties. Which of them came from the factory with twin Solex carburetors? A. Eurospec 1.8L B. Very early 1.7L C. Eurospec 2.0L D. None, all 914 four cylinders came with fuel injection. ------------------------- C A |
| bandjoey |
Jul 3 2014, 10:01 AM
The original Cabin Light has a chrome edge and is made in Mexico True / False The original Cabin Light has a White unobtanium switch True / False 1. False. It has a chrome edge but is made in Germany and is unobtanium. 2. True. ? I think u r right. Replacements do not have chrome and come from VW in Mexico, and originals had a white switch vs the black replacement ones. |
| Dave_Darling |
Jul 3 2014, 11:42 AM
You and a friend go to look at a 914 /6 you saw in the paper. It is advertised as an original six, but your friend says that it can’t be a real six because the key is in the right side of the column rather than in the dash on the left. You look under the dash, and you cannot see any evidence of wiring modifications. A. Your friend is right, it’s a conversion. B. It was a factory special order car. C. It is a real /6, made in 72 with a 4 cylinder column to cut costs. D. It is a real /6, with a 4 cylinder replacement column installed by a previous owner. Could be A, or C, or D. The ad could be wrong, and it is possible (with a bunch of work!) to swap in a -4 column if the -6 stuff completely fails. Or is burned. And the -6 stuff is much harder to find... Of course, I'm pretty sure you were going for C there, but the others could be argued. And likely thrown out by a protest. One of the ones from my old quizzes that Clay remembers fondly: A certain long-haired Californian has stolen all of the round relays from the relay board of Betty's 914! How many will she have to replace so she can chase him down? A. Depends on if her car is a 1.8 or not. B. Two C. Three D. All four of them I liked that quiz, it had several "repeating elements" that I thought were clever. One of which was the "Depends on if it is a 1.8 or not" answer; another of which was the "Borrow Mike Z's Sawz-all" answer. (I'm pretty sure that latter one was never the correct answer, but it might have been.... (IMG:style_emoticons/default/wink.gif) ) --DD |
Lo-Fi Version | Time is now: 12th April 2026 - 05:20 PM |
