| mobymutt |
Jul 3 2014, 03:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
For a '74 /4, with stock brakes. I need to adjust the venting, and I can't remove the inner adjuster covers, thus attempting to remove the calipers to get at them. I can't seem to fit a socket and breaker bar in there, what are my best options for tools to get the bolts loose, assuming I'll have to buy something anyway?
Thanks! Matt |
| hndyhrr |
Jul 3 2014, 04:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 698 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest
For a '74 /4, with stock brakes. I need to adjust the venting, and I can't remove the inner adjuster covers, thus attempting to remove the calipers to get at them. I can't seem to fit a socket and breaker bar in there, what are my best options for tools to get the bolts loose, assuming I'll have to buy something anyway? Thanks! Matt lets see mine is a 70, the back side mine i had to use a 4mm allen thru the control arm to get the cap off, then the same allen to adjust vent for the back side. to get caliper off I used a big wrench on caliper bolt with urging from a hammer. |
| SLITS |
Jul 3 2014, 04:23 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
19mm box end wrench
Needle nose pliers for pad locking pins and e-brake pin |
| mobymutt |
Jul 3 2014, 04:45 PM
| hndyhrr |
Jul 3 2014, 04:48 PM
| PlantMan |
Jul 3 2014, 04:57 PM
Member ![]() ![]() Group: Members Posts: 462 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
For a '74 /4, with stock brakes. I need to adjust the venting, and I can't remove the inner adjuster covers, thus attempting to remove the calipers to get at them. I can't seem to fit a socket and breaker bar in there, what are my best options for tools to get the bolts loose, assuming I'll have to buy something anyway? Thanks! Matt Use some BP Catalyst or WD40 and let them soak an hour or so. A box wrench should do fine, that is how I removed mine. If you have a Dead blow hammer that would help with loosening them up too. A small section of pipe for extra leverage would be ideal if you can fit it in the well and over your wrench. That inner adjuster is going to be a pain to get off without removing the caliper. Good Luck. |
| Dave_Darling |
Jul 3 2014, 06:19 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,365 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I dislike the 19mm open-end wrenches in my set. (Craftsman, BTW.) Could have something to do with them rounding off the fill plug on the transmission of my CRX... The jaws would open up enough to slip on the head of the fastener when I really reefed on the wrench.
Box-end wrenches don't do that. --DD |
Lo-Fi Version | Time is now: 5th November 2026 - 07:14 PM |
