Free Struts, Should I use them? |
Jetsetsurfshop |
Jul 5 2014, 03:17 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
A friend of my dad gave me these. They are just under 30mm raised. They also are shortened one inch. The tie rod arm has been modified too. The brake calipers mounts are 3 1/2 inch on center too.
Should I clean them up and use them? Worried about the 1 inch shortened mod and the bent tie-rod arm. I assume the tie-rod is bent to help with bump steer? I already have early 911 towers. So my brakes should mount right up. If I space out the front wheels, can I still use 15 inch wheels? How much spacing? Decambered ball joints help with fitment too? As usually, all help is good help. (IMG:style_emoticons/default/aktion035.gif) Attached thumbnail(s) |
Jetsetsurfshop |
Jul 5 2014, 03:20 PM
Another pic.... (IMG:style_emoticons/default/beerchug.gif)
Jetsetsurfshop |
Jul 5 2014, 03:21 PM
And another pic... (IMG:style_emoticons/default/beerchug.gif)
Krieger |
Jul 5 2014, 04:53 PM
Advanced Member Group: Members Posts: 4,704 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I would check to see if the struts are worn where the outer bearing sit. If you can feel a notch probably on the bottom of the strut you will have what seems like loose wheel bearings no matter how much you tighten them. I wonder what shocks are in those Koni cans?
Jetsetsurfshop |
Jul 5 2014, 05:19 PM
brant |
Jul 5 2014, 07:44 PM
914 Wizard Group: Members Posts: 11,617 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Those are interesting. Carrera I bet
ablesnead |
Jul 5 2014, 08:40 PM
Member Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None |
I dont think the 30mm will clear a 15 inch wheel without spacers
Jetsetsurfshop |
Jul 6 2014, 06:00 AM
I dont think the 30mm will clear a 15 inch wheel without spacers I don't either. (IMG:style_emoticons/default/sad.gif) We'll see. |
Woody |
Jul 6 2014, 09:43 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Jetsetsurfshop |
Jul 6 2014, 01:27 PM
brant |
Jul 6 2014, 04:01 PM
Those are nice shocks. They are ordered to length for a heavily lowered car. Now owned by qa1.
Lo-Fi Version | Time is now: 2nd May 2024 - 04:38 AM |
