fuel filler cap, Fuel filler cap |
rhd914 |
Jul 6 2014, 04:08 AM
Newbie Group: Members Posts: 44 Joined: 11-November 03 From: Australia Member No.: 1,332 |
HI, I have a problem on my '73 model. If I have any more than half a tank of fuel, I get a bad fuel smell from front of car. Checked it this morning and the area under the filler cap is wet from fuel sloshing around and coming from under the cap.
Does the later plastic cap seal better? If so, does it fit an earlier tank? Or do I have to replace the filler neck? Thanks Geoff |
rmdinmd |
Jul 6 2014, 04:16 AM
Member Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States |
you can get a replacement seal from 914rubber.com.
Harpo |
Jul 6 2014, 05:00 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
The flange on the tanks are the same (early & late) but you would have to change necks
Dave |
Mikey914 |
Jul 6 2014, 08:50 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The flange is the same. Seals are the same. pretty simple job. Check the seal on the VDO sensor while you are there too.
rhodyguy |
Jul 6 2014, 09:47 AM
There should also be a small line that connects to the filler neck that goes to the large plenum type piece on top of the tank, and another that goes to the charcoal cannister. The whole package, along with the new cap seal, needs to be in working order.
bdstone914 |
Jul 6 2014, 11:43 AM
Early and late gas caps, filler necks and expansion tanks are not interchangable. The brackets on the tank are different.
The late expansion tank is one piece with the filler as a molded part. The cap is threaded. It will not fit an early filler neck. There us also a rubber gasket up inside the early cap. They go bad too. I do not think replacements are available. |
Harpo |
Jul 6 2014, 11:57 AM
I was able to back date my gas tank components. The bolt pattern on the tank is the same on early & late.
David |
bdstone914 |
Jul 6 2014, 01:26 PM
I was able to back date my gas tank components. The bolt pattern on the tank is the same on early & late. David The mounting brackets for the expansion tank are different. Did you have a tank with a plastic expansion tank and install a steel one? Maybe you just mounted it to the holes around the filler neck and not the brackets on the tank ? No hood clearance problems? |
Lo-Fi Version | Time is now: 19th May 2024 - 02:08 AM |
