Door braces |
Door braces |
914itis |
Jul 12 2014, 09:24 PM
In the coming days, I will be installing an outer long stiffning kit from brad.
I know that I will need door braces. Where do I get a set ? and do I need to remove the doors to install them? |
76-914 |
Jul 13 2014, 08:00 AM
You don't "need" door braces but it's not a bad idea if your concerned. Myself and others have done it w/o the braces and w/o incident. When welding, I did 3 welds per side spaced as far apart as possible then moved to the other side and repeated. Keep an air hose close for cooling, if needed. Never let the surface get too hot. IOW, if you can put your cheek against it, your good. Put some masking tape next to the door gap and write down the gap measurements before you start welding. Check those gaps frequently as you weld. I think I experienced 1mm shrinkage but I forget. Look back at the beginning of my build thread and it is outlined. Another member posted the same results that I had doing it the same way.
EDIT: Shit; I just read your's is the outer so I can't speak to that one> Mine was an inner long kit. Sorry. |
injunmort |
Jul 13 2014, 09:23 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
you can make them if so inclined but I think it is easier just buy from racer chris. I used mine on three different cars. they come in handy.
infraredcalvin |
Jul 13 2014, 10:42 AM
Distracted Member Group: Members Posts: 1,517 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
you can make them if so inclined but I think it is easier just buy from racer chris. I used mine on three different cars. they come in handy. (IMG:style_emoticons/default/agree.gif) I spent a bunch of time trying to go cheap and make some. In the end I wasn't happy with the results, I finally broke down and bought Chris'. Should have done that first, I really like them. |
rgalla9146 |
Jul 13 2014, 11:44 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Hey Paul
Come get 'em Came from Luke Martini with the GT project. Not being used right now. Fixed length. Top door hinge-to-shoulder belt mount. Doors off. Rory |
Elliot Cannon |
Jul 13 2014, 11:50 AM
If your welding skills are good enough to install the stiffening kit (assuming you are doing the instalation), you should be able to make your own door braces. I made mine and it was a lot easier to make them than it was to install the Egman inner long kit. (IMG:style_emoticons/default/biggrin.gif)
914itis |
Jul 13 2014, 04:56 PM
Lo-Fi Version | Time is now: 17th May 2024 - 03:58 PM |
