No headlights, Hi Beams but not low beams |
swooshdave |
Jul 13 2014, 06:48 PM
Member Group: Members Posts: 184 Joined: 11-June 14 From: Portland Member No.: 17,475 Region Association: Pacific Northwest |
Low beams don't work. High beams do.
Swapped relay (it's new) with another new one with no change. Stalk has been changed at some point. Where should I look next? At the stalk? A fuse? Somewhere else I can check for power? |
zambezi |
Jul 13 2014, 08:37 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Yes fuses. There are individual fuses for each high/low and left/right (4 fuses total). Your feet can sometimes bump the fuse panel when you get out of the car and knock some fuses loose.
Mike Bellis |
Jul 13 2014, 09:09 PM
You should hear the hi/lo relay click when pulling the turn stalk. Yes/no?
swooshdave |
Jul 13 2014, 09:20 PM
I looked at the fuses and they didn't look askew or shorted. I would think it would be pretty unusual to bump just the low beams.
I can check for power at the fuses. |
bdstone914 |
Had a similar problem. Could hear the Hi low relay click but no Hi beams. Cleaned the points in the relay by dragging a piece of paper between them.
Bruce |
Lo-Fi Version | Time is now: 17th May 2024 - 04:46 PM |
